Thread: Skimmer drain question & 60 cold enough?
    May 2016
    Hopkinton, MA
    105
    There are two holes in the bottom of the skimmer basket.
    What are each of them for? I don't want to screw up this closing. My husband is adamant that we do this today. I am thinking that water at 60 is too warm, and I don't know what the two holes are in the drain... Help? Thank you
    In ground Liner, MBP-125A Heat Pump by Aqua Heat , built 2003, 18x37 Grecian style, System 3 sta-rite filter. @22,000 gal, Poolmaster 22260 5-Way Test Kit, USQ1102pump installed 6/2016
    Catanzaro's Avatar
    Jul 2014
    Monmouth County, New Jersey
    2,202
    Re: Skimmer drain question & 60 cold enough?
    Do you have a main drain? If so, it may be part of the same plumbing. It could also be so the skimmer water level is protected. Use the search function on the forum and there are a lot of posts explaining the difference. Do you have shut off valves for skimmer or what is on the suction side? Who has closed pool before?
    14,700 gallons IG Pool Vinyl Liner - Octal Circulation System
    Hayward Pro-Series 350 LB. Sand Filter Model # S270T - 2" Plumping
    Hayward CL2002 Chlorinator - Hayward Super Pump 2 HP Model # k48m2n111
    Hayward AQR9 SWG 25K Salt Cell & TF-100 Test Kit + Speed Stir
    Gulfstream HE125RA - 117K BTU Heat Pump - Date of Build is 11-2013
    May 2016
    Hopkinton, MA
    105
    Well, seeing as how it's a week later. I convinced my husband to wait on closing.
    Last year we had just bought the house, so pool company did it, and they opened it as well- green green green.. so found this site and decided never again.
    I have 2 tubes one for the MD in deep end, and one for the skimmer. Both have shut off independent of the other. I also have a spigot thing at the front of the filter.
    Upon trying to get a good pic of the holes in the skimmer, I noticed that only one hole is open, the other is capped off. Guess I only have to lower the water and suck it out then plug it. Then blow the main drain I don't know where to attach the blower/suction to on the filter area.. attached picture14765447139521284609974.jpg
    Catanzaro's Avatar
    Jul 2014
    2,202
    You still will have to blow out the lines, unless you add pool anti-freeze in the lines. The MD should be blown out properly as well, including the returns. Winterize the filter and remove all accessories, etc.
