Results 1 to 10 of 10
Thread: Will this be a problem in New England?
    Jun 2016
    New England
    77
    They don't seem to be draining. I'm worried about cracked cement when I open. This is the first time closing the pool myself.
    Christopher
    21' x 43' IG 40K Gallon vinyl and concrete pool; liner: 2016; Hayward DE7220 filter; Maytronics M400; TFT-100; Speed-Stir
    Sep 2013
    Connecticut
    728
    Re: Will this be a problem in New England?
    Sorry, I'm probably being dense here... but what exactly are we looking at?
    18' x 48" ring top pool (Summer Escapes); 5500 gallons; set up June - October, stored during winter; Intex 2500 gph pump (B size cartridge filter) Hayward 21" sand filter + 1.5 hp single speed Powerflo Matrix pump (upgrade October 2016) *** K-2006 test kit, refills from tftestkits
    Jun 2016
    New England
    77
    Quote Originally Posted by singingpond View Post
    The hole the ladders mount into. There is suppose to be a drain hole but they don't seem to be doing anything. I have four holes, two for the ladder in the deep end and one for the pole by the shallow end stairs. They all hold water like this.
    Christopher
    Aug 2016
    Pittsburgh PA
    191
    Put a hose in there and blow it out. Your drains are probably clogged up.
    borjis's Avatar
    Aug 2014
    Pacific NW
    1,531
    Mine don't drain either. I just blow them out and put something heavy over it to keep rain out.
    Mod Squad JohnT's Avatar
    SW Indiana
    8,718
    There is usually a drain hole in the bottom. Sometimes filled with concrete during installation and often clogged with debris. Use a hose as suggested above.
    PoolguyinCT's Avatar
    Jul 2014
    Connecticut
    253
    Stuff it with a piece of pool noodle & move on
    Jun 2016
    New England
    77
    Quote Originally Posted by PoolguyinCT View Post
    How does that help? I've seen that mentioned before but won't it just freeze around it and do pretty much the same?
    Christopher
    SW Indiana
    8,718
    Quote Originally Posted by SirSwimAlot View Post
    When the ice expands, it crushes the noodle rather than putting force on the anchor. The noodle also greatly reduces how much water is there to start with.
    n240sxguy's Avatar
    May 2014
    Benton, KY
    1,409
    Does your cover not go over them? I think mine does, but now I'm gonna have to check.
    33K gallon IG vinyl. 1.5HP Waterway Mustang pump. 600 lb sand filter. Polaris 280. Circupool SI-60+. TF-100XL
