Thread: yellowish green algae
    Oct 2016
    Rockville
    3
    Need help with algae. Yellowish green color. After an opening in May ,upper part of pool where level of the water risen during winter, appear an discoloration of a yellow greenish color. After opening only shade part of the pool affected. Tried evereything - slamming pool, using cleaning stone, antialgae side etc.
    24000 gallons, in ground, salt generator pool,Triton sand filter, 3/4 hp pump.
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,782
    Re: yellowish green algae
    Welcome. Do you have any ACCURATE test results for us to look at? Have one of our recommended test kits?
    Oct 2016
    Rockville
    3
    Quote Originally Posted by woodyp View Post
    I am trying to post photos but can not proceed.Can you help?
    Oct 2016
    Rockville
    3
    Quote Originally Posted by vladyasha View Post
    free chlorine 2
    available chlorine 2
    salt 2700 i know it is low
    calcium hardness 240
    cya 60
    ta 110
    ph 8 need more acid
    copper 0
    iron 0
    phosphate 100
    borjis's Avatar
    Aug 2014
    Pacific NW
    2,399
    Your free chlorine is too low...do you normally allow it to get to 2?
    At your CYA level, it needs to be around 6 (4 minimum) at all times to prevent algae growth.
    If you do the slam properly and to the letter while brushing daily, it will go away.
    Dolphin E10 Cleaning Robot.
