Thread: Weird shaped pool and need solar cover and reel
    Amanda B's Avatar
    Sep 2016
    Indiana
    47
    I want to get a solar cover and reel for my pool. The shape of my pool is curvy, Mt. Lake is the name of the design. At its widest it is 21 foot and it is 40 ft long. I know I will not find a solar cover shaped to fit, would an oval or rectangle 21x40ish work if I cut it? Also, I cannot seem to find a good reel that will also fit. I find 20 ft wide ones...Any suggestions?
    21x40 Legacy Mountain Lake about 17,000 gallons, Slate Gray Liner. Hayward S 200 Series Sand filter, Hayward Goldline Aquarite SWG T-Cell 15) , and Hayward Super Pump. Automated on a timer system! Dolphin M400 cleaner. Taylor K 2005 test kit and K-1766. Stamped concrete and pool house.
    Mod Squad pooldv's Avatar
    DFW, TX
    22,932
    Re: Weird shaped pool and need solar cover and reel
    My pool is similar. I bought a 20x40 oval 8 mil cover and cut it. It works great and was easy to cut with scissors. This roller might work better, DIY Solar Cover Roller. Probably cut into two 20ish foot pieces.
    Amanda B's Avatar
    Sep 2016
    Indiana
    47
    Thanks!
