Thread: High bromine... does it affect ph?
    Jan 2016
    KS
    62
    I know in my pool that when shocking and chlorine is above 10 you cannot get an accurate reading wih ph. Is that the case with bromine too?. I had lowered the ph to 7.0 before to lower ta from 100 to 50. I have aerated it back up to 7.5. I added bromine and shocked and now getting a 8.0+ ph. Is this skewed from high bromine or do i need to add a little acid? Currently bromine is 12.5. Ta 60
    36,000 Gallon, 40x20 IG, Vinyl, Hayward S- 200 Sand Filter, 300,000 MasterTemp heater, 1hp Superpump, Polaris 9550 sport, TF100 test kit
    domct203's Avatar
    Jun 2015
    CT
    3,690
    Re: High bromine... does it affect ph?
    Is this a bromine pool or a chlorine pool? Bromine should not be added, or needed in a chlorine pool.
    Dom - TFP Guide
    Intex 18' X 48" Ultra Frame AGP 6700 gallons | Two Intex CS8110 SWG's | Hayward Pro Series 21" Sandfilter | Hayward 1.5HP Power Flo Matrix pump | Hayward Thru-wall Skimmer | Wanda the Whale | 72 sq ft of Sungrabber Solar Panels with Hayward GLC-2P-A | Taylor K2006 Test Kit, Sample Sizer & Speed Stir | Click Here To Become a TFP Supporter!
    Jan 2016
    KS
    62
    Quote Originally Posted by domct203 View Post
    Sorry for confusion. My pool is chlorine and my completely separate spa is bromine. I only referenced the pool because that is what i have been told in the past.
    My question is regarding the bromine spa only. Chlorine pool is closed for winter
