Thread: What should FC be when closing pool?
    Jun 2016
    New England
    98
    In the guide, it says to slam the pool, then let it come down to normal levels.
    I also read other people saying they close the pool at slam levels.
    Christopher
    21' x 43' IG 40K Gallon vinyl and concrete pool; liner: 2016; Hayward DE7220 filter; Maytronics M400; TFT-100; Speed-Stir
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Re: What should FC be when closing pool?
    I bring the FC up to shock level for my CYA the day/night before closing. Then I close the next day. It's not overly critical what FC you close at as long as it's elevated above target levels. It's more critical that your water is cold. 60 degrees.
    Isolated Spa - 345 Gallons
