Thread: How to repair slide
    How to repair slide
    I have a slide that has a few rough spots on it from wear and tear. The blue coating is gone in a few places. What do you to repair the slide? Is there a paint you buy or a wax?
    36,000 buster crabbe inground vinyl aquagenie
    1 hp hayward sand filter
    New Jersey
    If it is Plastic, you might try painting it with Krylon paint for plastic.
    It is supposed to "bond on a molecular level", which I imagine is good !!
    it's likely fiberglass - your best bet is to recoat it with gelcoat - available in a paint can at a marine supply store - used on boats for resurfacing, if you have air tools, spray it on, otherwise brush it, it should flow nice and smooth.
    Fix the bad spots with a couple of layers first, let cure, sand the overlap spots so it's nice and blended, then give it a few top coats.
