Results 1 to 12 of 12
Thread: Pool depth
    Drew80's Avatar
    Feb 2013
    Austin, TX
    102
    Pool depth
    Another thread about planning our new build in Austin, TX. We're not interested in a "deep end" of the pool - we just want a party pool where adults can stand comfortably, and we will probably occasionally play volleyball. Two questions:
    1. What depth should that be? 4'? Should we have an area deeper than that to keep temperatures cool?
    2. Assuming we don't need a deeper area for cooling, is there another reason the floor should slope, or can we do a continuous level?
    Jan 2012
    'burbs of Augusta, Georgia
    7,139
    Re: Pool depth
    Do you ever want to swim in this pool? Because making it too shallow risks scraped knuckles on the bottom. I would make the minimum depth 4 feet, and the rest 5 feet. People do like to stand in water, float in tubes and on noodles, etc.
    And yeah... too shallow you do risk it feeling like swamp water in July and August in hot climates.
    Yippee
    Mod Squad Jimrahbe's Avatar
    Jul 2014
    Bedford, TX
    6,952
    Re: Pool depth
    Drew,
    What you want is a "play pool".. normally 3.5' to 4' on each end, and 6' or so, in the middle. Works great for playing volley ball.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,201
    Re: Pool depth
    4' x 5' x 4' is perfect. 3.5' is too shallow
    May 2016
    West Bloomfield, MI
    685
    Re: Pool depth
    Quote Originally Posted by Jimrahbe View Post
    Drew,
    Friends of mine had this layout. They called it a "sports pool", and they loved it.
    12,000 gal Diamond Brite indoor​ pool. Pentair Triton TR-60 Sand Filter +added DE, Lochinvar Energyrite ERN-200 gas heater, Pentair Multi-valve, Pentair SuperFlo VS pump, TF-100 kit, Pool Math App - iOS
    Jan 2012
    7,139
    Re: Pool depth
    But keep in mind Rollercoastr- Michigan doesn't get near as hot as Austin, TX and the swim season is much longer there. I think a little extra depth is going to provide more options as well as being more comfortable.
    May 2016
    West Bloomfield, MI
    685
    Re: Pool depth
    Yip, these "play/sports pools" are deep in the center. (although it's admittedly hard to tell in that real-estate listing pic) If you look at the reflection from the master bedroom windows, you can see how the bottom comes to a fairly sharp V.
    Jimrabhe mentioned a 6' deep section. I think my friends had over 6' of depth in the center.
    Sadly, they sold the home before I could hook them up with TFP!
    Jan 2012
    7,139
    Re: Pool depth
    I looked at your picture again and now I see what you mean. When I read "play pools" I imagined one depth the entire pool.
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Re: Pool depth
    One other thing to keep in mind if this is a Shotcrete pool then where pool builders end up ordering too much Shotcrete (wet mix) in the concrete truck they often put it on too thick making the pool shallower than planned. Also make sure you agree with your pool building depth measured to the water line, not depth measured to the edge of the pool
    Drew80's Avatar
    Feb 2013
    Austin, TX
    102
    Re: Pool depth
    Thanks for all the answers! I think we'll go 4-5-4. 6' is just too deep for anyone to be able to stand, and we definitely don't need a 3.5' section.
    DFW, TX
    24,201
    Re: Pool depth
    Agreed. 6' is not a useful depth. Still not good for diving or deep swimming and only LeBron can stand up.
    platipus's Avatar
    Feb 2015
    Houston, TX
    374
    Re: Pool depth
    Another vote for the 4-5-4 layout. I'm 6' and my wife is 5' 3". There's a "sweet spot" for both of us to hang out at.
    plat.
    Modern Geometric-ish Social Pool (4'-5'-4') ~13' x 47'. Sun shelf. Perimeter overflow spa. RiverFlow Swimjet. Dog ramp. "Bubble Lounge"
    Link to my patio build, completed 2013
    Link to my pool build, Aug '15 - Sep '16
