Thread: Closing, how to pull from main drain
    Nov 2015
    Boston, MA
    107
    I started lowering the water below skimmers in IG pool. I then was like i should check the ph and it was high around 8. Was going to add some muriatic acid by then thought how can i recirculate if water is below skimmer? I figured i could just set the pump to recirculate instead of filter and only open the main drain but when i do that the pump still keeps trying to get up to prime like its still trying to pull air from the closed skimmers. I pushed down the valves on L and R skimmer valves but appears its still trying to suck from there.
    Sorry valves werent down all the way
    18x44 double Roman vinyl pool, Hayward superpump, Hayward DE Filter,
    Aqua Rite T15 SWG, Taylor k 2006 test kit
    Catanzaro's Avatar
    Jul 2014
    Howell, New Jersey
    1,166
    Re: Closing, how to pull from main drain
    You are all set? Thanks!
    14,700 gallons IG Pool Vinyl Liner - Octal Circulation System
    Hayward Pro-Series 350 LB. Sand Filter Model # S270T - 2" Plumping
    Frog Mineralizer System (EMPTY) - Hayward Super Pump 2 HP Model # k48m2n111
    Pool Company tests water (NO LONGER) TF-100 TEST KIT
    Date of Build is 11-2013
    Nov 2015
    Boston, MA
    107
    Quote Originally Posted by Catanzaro View Post
    All set thanks
