Results 1 to 9 of 9
Thread: Do Chlorine Generators Recycle Salt?
    Jun 2015
    Clearwater
    10
    Recently I found an article on an autopilot site. The quote reads this:
    "The main benefit a salt chlorine generator offers is its ability to recycle salt. During the process of electrolysis, as used in a salt chlorine generator to produce chlorine, the chlorine breaks down further into hypochlorous acid and hypochlorite ions, which are sanitizers. After the hypochlorous acid and hypochlorite ions neutralize the contaminants in swimming pool water, they revert to salt, again, only to be broken down into chlorine for another cycle."
    I've never heard anything like this before. Is this true, partially true, misleading, etc.? If it recycles the salt then why would you ever need to add salt again. Simply bring it up to 3500ppm and you're set.
    Like some clarification on this one.
    Thanks
    17K Inground Pool
    Cartridge Filter
    pabeader's Avatar
    May 2015
    Dallas Ga
    3,625
    Re: Do Chlorine Generators Recycle Salt?
    In normal practice, this is exactly right. You never have to add any salt if you never have any water exchange. But, as most pools have some form of fresh water introduced, there is a need to top off the salt level from time to time.
    Bob - Palm Beach by San Juan Pools. approx 5000 gals., Pentair 320 cartridge filter (all new guts installed by me), Goldline SWG, 'New to me' Kreepy Krauly Sand Shark, Intermec 104 Timer Test kit: TF-100 w/Speed Stir
    Jan 2016
    grande prairie
    29
    my swg pool and tub only need salt when I drain and fill or replace water from splashout. When evaporation occurs the salt doesnt come out. When my pool had an underground leak the salt level went down indicating a problem.
    113,000L indoor saltwater pool built in 1981. 1000lb sand filter, filed with quartz with 2hp single speed pump.
    4602L indoor saltwater whirlpool built in 1981. 500lb sand filter with 2hp single speed pump. Both controlled by chemtrol250 and Hayward pro swg's.
    GaryT58's Avatar
    Jul 2016
    Monroe, GA
    520
    Will repeat from above. Will only lose salt from runoff- be it overflow, backwash, splash out, ... Not from evaporation. So rather than purchasing chlorine, you have up front cost of salt water chlorine generator (SWG) and salt. Then electricity. And eventually replacing the cell.
    38'x16' Fiberglass pool - 3.5' - 8' deep - 19,000 gallons. AutoPilot Total Control SWG (RC-52 cell), Pentair SuperFlo VS, Pentair SD70 Sand Filter, Coverstar Automatic Cover, 10' board, PAL Treo lighting, Polaris 9550 Sport robot, Lamotte ColorQ Pro 7 test kit.
    The chlorine atoms basically gain and lose electrons. With 8 electrons in the outer shell, the chlorine atom is a chloride ion. As the chloride goes through the cell, it loses an electron to become chlorine. As chlorine oxidizes something, it gains electrons and becomes chloride again.
    JoyfulNoise's Avatar
    May 2015
    8,750
    I have never had to add salt to my SWG pool since starting it up years ago.
    Municipal water contains chloride (mine is 160ppm). Also, any chlorine source be it solid chlorine (trichlor, dichlor or cal-hypo) as well as liquid chlorine eventually adds salt because chlorine is converted to chloride once it reacts with something.
    Muriatic acid also adds chloride to your pool as it is hydrogen chloride.
    All pools are salt water pools...
    Matt
    Jul 2014
    Hope Mills, NC
    482
    But not all pools are SWG pools...YET!!!
    16 x 32 17500 gallons
    Vinyl in-ground
    Hayward 250# Sand Filter
    1 HP Pump
    Hayward SWG
    AUSpool's Avatar
    Sep 2015
    Sunshine Coast, Australia.
    331
    I have never had to add salt to my SWG pool since starting it up years ago...
    With lots of rain we're the exact opposite, been through truck loads of the stuff. The world almost ended when supplies ran out after our last big flood.
    Steve.
    30,000L (8,000g) Pebblecrete | Davey 3sp Eco pump | Poolrite sand filter & SWCG |
    Waterco solar panels & Astral E140 pump| K2006, CCL reagents, BlueDevil pH, Salt meter & K1766 | Town water - pH 7.2, TA 50, CH 60 | Esky full of coldies |
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    4,867
    This is pretty much right. the salt in the water goes through the SWG plates and an electrolysis reaction and chlorine is generated and sent to the pool. Just as James described it. Once the chlorine does it's job, it turns into salt again.
    You only have to replenish the salt occasionaly. The salt level will drop due to splash out, overflow from heavy rains, backwashing the filter, etc.
    It sure is nice not to have to put chlorine into the pool every day or use chlorine pucks which also add other unwated chemicals to the water, or worry about it if you go away from home for a few days. The SWG will keep on doing it's thing and keep the pool chlorinated.
    As an added benefit, the bit of salt in the water feels nice on the skin. The feel of salt water has been described and I would agree, as a little bit 'silky'.
    Quote Originally Posted by RobRM View Post
    Thanks
    Divin Dave,
