Thread: Polaris Feeder Will Not Calibrate Lower
    Oct 2016
    Malakwa, BC
    1
    Hi ,
    I am using a Polaris Watermatic feeding system for Chlorine and Muriatic Acid.
    Lately when I get my PH reading and try to calibrate lower on the feeder it will not allow me to do so. I can only calibrate higher.
    Anyone have any suggestions on what the problem might be? I am going to clean my sensor tips today in case that might have something to do with it.
    TIA
    3 in ground, outdoor commercial pools/ Pool 1#- 711 sq. ft., 3.5 ft deep/ pool #2- 600 sq. ft., 3.5 ft. deep / Pool #3- 783 sq. ft., 3.5 ft. deep
    All pools- 42" Non-Corrosive Horizontal Fluid Filtration System/ Bell & Gossett series 1531 Centrifugal pumps/ Polaris Watermatic automated liquid chlorine feeder system
    Apr 2013
    Sacramento, CA
    2,769
    Re: Polaris Feeder Will Not Calibrate Lower
