Thread: Weeping Gunite
    First Pool Judith's Avatar
    Feb 2014
    Georgetown, Texas
    55
    Weeping Gunite
    Our gunite was poured for our second pool build 9/24/16. It still has some places where it's weeping and it looks like it has calcium build up. I'm not an expert, but should something be done about this? Wouldn't this weeping affect the plaster once they put it on top? Picture attached. You can see what I'm referring to across from the coping, mid way down on the bench. Please advise.pool pic 1.jpg
    Judith and Brian D
    16,000 gal; IG Quartscape; Cartridge Jandy CV460 (150 gpm Max); Jandy Pro 2.0 Variable
    Polaris PB460 3/4 booster; Polaris 280 Cleaner; In Line Chlorinator Tri-Chlor (don't use it) Ozonator
    Fill Date 11/11/2013
    Jul 2016
    Rancho Cucamonga, CA
    231
    Re: Weeping Gunite
    I was a bit concerened about some spots in my pool, but, it slowly but surely went away and stopped (quickly once we stopped watering). Check out my build thread... gunite happened... oh... maybe page 4 or so. I took a photo similar to yours with weeping... yours isn't too much 'worse' than mine.
    Pool-15x31', Spa-7x9', depth 3.5-6', HP Pentair Whisper Flow pump/motor, Intelliflo 8-160, 4-to-8 speed, Pentair 320 Clean and Clear capacity filter (upgraded to 400,000BTU stackless heater). Stacked stone- Autumn Rose Classic, tile- Ridgeline Blue Slate, coping- Turning Leaf Quartzite. Start date 7/12/16! Progress thread
