Thread: White lithium grease as lube?
    Jun 2016
    Asheville nc
    20
    I picked up lithium grease for my gaskets.
    Then I read here, (one day I will learn...)
    Is this a bad product to use on my rubber gaskets?
    Thanks
    18x48 intex AG, 2650 Intex sand filter and salt system, I think around 5500 gallons
    Mod Squad pooldv's Avatar
    DFW, TX
    24,201
    Re: White lithium grease as lube?
    I don't know if it is bad or not. But, I do know that rubber o-rings and gaskets should be lubed with silicone lube. I use plumber's grease from Lowes.
    JoyfulNoise's Avatar
    May 2015
    12,874
    100% pure silicone lube (BOSS Lube #820) - https://www.poolpartsonline.com/p-36...3OLhoCL9Hw_wcB
    Stay away from silicone lubes that have Teflon in them. The chemicals that form the Teflon in them react with air and moisture over time and become sticky.
    Do NOT use the lithium grease in the o-rings as they typically contain mineral oils that will breakdown the rubber. Lithium grease is intended for metallic parts to prevent galling, not to act as a sealant.
    Matt
    Jun 2016
    Asheville nc
    20
    Thank you!
