Thread: Hurricane coming
    May 2015
    Juno Beach , Florida
    210
    Hurricane coming
    Hi,
    I live in West Palm BEach Fl, and it seems a large hurricane is coming, or at least a very big storm. Might lose my pool screen, but hopefully not.
    Anyway, is there anything I should do to my perfectly balanced pool, before the storm comes?
    Is the pool water drinkable?
    Always keep it at:
    FC 5-6
    TA 80
    CYA 80
    PH 7.5
    Guess it will be a mess after the storm. Even though it is SWG, I always have about 12 gallons of bleach on hand.
    thx
    12k SWG pool, free form. 1HP flotec pump, P90 Leslie's filter. Florida. Taylor 2006 test kit. I think plaster, waiting verification from here.
    Mod Squad JohnT's Avatar
    SW Indiana
    9,100
    Re: Hurricane coming
    No, the CYA makes it unsuitable for drinking. Fine for flushing toilets or bathing though.
    Probably not much you can do chemically. If you are at risk for flooding, you might want to remove your pump, SWCG etc. and place them out of reach of the water.
    It's important that your pool is full. This helps keep ground water from raising the shell.
    Isaac-1's Avatar
    SW Louisiana
    6,711
    You may want to raise your FC up to SLAM level in advance as lots of organics will likely be blown in
    Mod Squad tim5055's Avatar
    May 2014
    Columbia, SC
    8,528
    Quote Originally Posted by Isaac-1 View Post
    This is what I plan on doing....
    Expecting lots of wind and rain in our inland area.
    TFP Moderator 39 X 18 23,000(ish) freeform gunite; built 2007ish; Pentair Triton II TR100 600lb Sand filter; 2 HP Pentair pump with 2.2 HP AO Smith single speed motor; 2 skimmers, 1 main drain, 4 returns w/waterfall, Stenner 45MHP2 3GPD running@ 60% - 15 gal Tank; heated by the sun CYA 200+ when I started - 50 now. Dolphin Supreme M5 Pool Cleaner. Hot Springs SX Spa, 285 gallon
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,067
    I'd be more worried about FC at SLAM level that a bit of CYA over a short period of time for potable water. HOPEFULLY you have some bottled water on hand. Always a good plan any way. Still plenty of time to fill empty containers with tap water if stores are out in your area. Unfortunately though, you'll have more than enough water falling from the sky you can use a few drops of that bleach on for drinking water too.
    May 2015
    210
    Thanks for the advice. Ok on supplies - I always keep 14 flats of water bottles, food, 4 full propane gas canisters, and 10 gallons of bleach, at all times. So I did not need to do any panic buying. Metal storm shutters are all up - that took 2 days!
    Will turn off pump now and add some bleach.
    my biggest concern is my pool screen, but I have no control over that, so no point in worrying.....
