Thread: Confused how to shock my above ground pool before closing.
    Dec 2015
    Hamilton
    17
    Hi everyone,
    First time pool owner preforming his first time pool closing.
    I have an 18' round Salt water pool with a SWG. I bought the pool closing kit from costco, with the algecide, and antifreeze, and other stuff. But it seems like I don't need it.
    Can anyone help me figure out how much bleach to put in the pool to bring it to shock level?
    Once it's in shock level, all I gotta do is drain it below the return, make sure there is no water in the lines and put the cover on, correct?
    Thank you!!!
    18' Round AG. 8200 Gallons. Hayward Aqua Troll SWG. 1HP Hayward Pump. Hayward sand filter.
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,181
    Re: Confused how to shock my above ground pool before closing.
    Which state are you in? Region can sometimes make a difference in assistance offered.
    Pool Math can tell you everything you need.
    Which test kit do you have? K-2006C or TF-100?
    Bob - INTEX 12x24 owner (not setup yet), 'New to me' Kreepy Krauly Sand Shark, Test kit: TF-100 w/Speed Stir
    Dec 2015
    Hamilton
    17
    I'm in Ontario Canada. Do I need one of those kits just to close the pool this season?
    Is there no general rule about how much bleach per how many gallons for closing?
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,181
    Not really. The one thing you will learn here is that we do most everything based on the numbers from one of the test kits. If you don't know what your current level is, how can you know what to add to get where you want to be?
    That being said. All you need to close is bleach, and maybe poly 60 type algecide.
    Here is the post that explains it best: Pool School - Closing (Winterizing) Your Above Ground Pool
