Thread: Closing my pool
    Oct 2016
    Exclamation Closing my pool
    Hello and good morning. I have successfully closed my pool and im trying to remove the flex hose from the pump and skimmer so I can store the pump indoors. It gets pretty cold where I live, so I store the pump inside for winter. My problem is, I cant get the flex hose off its so tight. Clamps are off but hose wont budge. Is there a way to easily remove these hoses? Last year I just cut them off. Next year I will place a quick release with a union to make it easier.
    Catanzaro's Avatar
    Jul 2014
    Monmouth County, New Jersey
    Re: Closing my pool
    Pumps are designed to be out in the cold. If the water is out, then the pump should be fine. Unions are best. Hard to figure out how to get off. You may be better off cutting again until next spring if you want the pump inside. Then put the unions together.
    14,700 gallons IG Pool Vinyl Liner - Octal Circulation System
    Hayward Pro-Series 350 LB. Sand Filter Model # S270T - 2" Plumping
    Hayward CL2002 Chlorinator - Hayward Super Pump 2 HP Model # k48m2n111
    Hayward AQR9 SWG 25K Salt Cell & TF-100 Test Kit + Speed Stir
    Gulfstream HE125RA - 117K BTU Heat Pump - Date of Build is 11-2013
    borjis's Avatar
    Aug 2014
    Pacific NW
    Re: Closing my pool
    Could be a barbed fitting, if it is, it won't come off, but will need to be cut.
    Dolphin E10 Cleaning Robot.
    PoolguyinCT's Avatar
    Jul 2014
    Re: Closing my pool
    If barbed- torch it to soften pipe.
