Results 1 to 7 of 7
Thread: Save money buying pump that had broken bolts?
    Oct 2010
    Eastern TN
    174
    My installer has a new Pentair variable speed pump that arrived with 2 broken bolts. It has full warranty and he ordered replacement bolts. He is willing to sell for $600. What do folks think about this vs paying another $400 for a new pump?
    Plaster pool inground 22,000 gallons with spa. Pentair Intelliflo, IC40 salt generator, WiFi control/Easy Touch.
    Hayward 1.5 HP pump on 750 gallon spa. Sand filters. Auto chlorinator on spa. Auto water level. Dolphin M500. TF100 XL with Speed Stir. Apera Instruments AI311 PH60 Premium Waterproof pH Pocket Tester
    PoolguyinCT's Avatar
    Jul 2014
    Connecticut
    1,551
    Re: Save money buying pump that had broken bolts?
    Pic??? With Pentair I'm inclined to think the bolts are actually "buried" put up a photo & I have a few McGuyvers for popping a few bad bolt situations.
    Ray
    Which bolts were broken on arrival?
    Bolts do not break easily. Something doesn't make sense. Typically, if bolts break, something has gone seriously wrong.
    If the pump arrived damaged, it should be covered under warranty and sent back to Pentair if it was their fault. If it was damaged in transit, then that goes to whomever caused the damage.
    I would pass on the deal. It just doesn't seem legit.
    Support the site
    Oct 2010
    Eastern TN
    174
    The installer already replaced the bolts. He told me that 2 of 4 bolts broke. I'm wondering if longevity of pump will be affected by rough handling in transit. Sounds like I may be better getting a new pump
    CJadamec's Avatar
    Apr 2016
    Quaker Hill, CT
    2,062
    Without know which bolt were replaced its impossible to say. If its the cover screws holding the electronics to the back of the pump might not be a big deal. If its the bolts that hold the pump housing to the motor I would be very suspect of how they got damaged. Also you didn't say which Pentair pump it is. A brand new Superflo VS pump retails for around 650 online. A brand new intelleflo retails in the 900-1200 range depending on the exact model.
    Chuck-
    15x30 AG, Pentair Superflo VS, 19" sand filter, TF-100 test kit
    Aqua Comfort ACT750 heat pump / 6x20 ground mount solar panel / DIY automation
    Photos of 2016 Build, Inside Your Breaker Panel, Free Copy of 2017 NEC code
    TFP is AD Free and is funded solely by member support click here to help
    Oct 2010
    Eastern TN
    174
    Oops. Intelliflow VS that I can get online for $935. He quoted job with equipment but I spoke with hime yesterday and he is ok with me getting equipment and he will install. Online pricing at times beats his cost.
    Teald024's Avatar
    Aug 2016
    Columbus, Ohio
    1,328
    Quote Originally Posted by DigitallyChallenged View Post
    Depending on which bolts broke, it sounds like the pump was dropped, dropped on, or smashed into. And since he is trying to sell it, it appears like it was their fault and they probably know exactly how it happened. If it wasn't their fault, they would charge it to the mfg under warranty or the shipper for their damage. I'd pass if it was me. Too much risk on an expensive pump. MFG warranty usually doesn't cover damage for mishandling.
    Glad to see that you decided to pass as well.
    Dave - Aqua Leader Elegance AGP 15'x30'x 54", 12k gallons, vinyl liner ... Hayward/SwimPro Voyager pump SW159412STL, 2hp, 2spd, Hayward/Voyager 175sf element filter SW175MDDVPAKS, Installed August 2016 ... Liquid Chlorine, Stenner, Woods 50015 timer ... TF-100 .... CYA/Chlorine Chart ... Recommended Levels ... Basic Care Schedule ... Extended-Test-Kit-Directions ... ABCs of Pool Water Chemistry
