Results 1 to 10 of 10
Thread: Pool closing-skimmer gizmo
    Aug 2015
    macomb twp
    30
    So i had a company close my pool. I went out there after a week and the skimmer gizmo plastic thing was floating in the skimmer. It has rained since then and the skimmer is full of water now. I called the well know company and he said just screw the gizmo back in. I said but its full of water now. He says" i put antifreeze in the line and it will be ok." Is this ok? Should i vacuum the skimmer line out and put more antifreeze back in then put the skimmer gizmo back in? Advice please, im a new pool owner
    12 X24 10000 gallon, Hayward AquaRite Tcell-9 SWG, vinyl pool, liner, Hayward MAX-FLO Hayward variable speed pump, Hayward H150FDN Universal H-Series, Low NOx, 150,000 BTU, Natural Gas, Pool heater, Sand filter
    Mod Squad JohnT's Avatar
    SW Indiana
    9,171
    Re: Pool closing-skimmer gizmo
    I'd blow it out. No question.
    PoolguyinCT's Avatar
    Jul 2014
    Connecticut
    1,215
    A flooded gizmo is junk, it will freeze & offer no contraction benefit.
    Purge the line it's flooded.
    Catanzaro's Avatar
    Jul 2014
    Monmouth County, New Jersey
    2,203
    PoolGuy, what do you mean by a "Flooded Gizmo"?
    Additionally, if this was my pool, the Gizmo was not installed properly after blowing the lines, I would call the company back to do this again. You paid for a service and the company should stand by the work they do. Depending on the skimmer line(s), water could have been introduced back to the other line (if you have one) and possibly back to the pump basket, etc. Please inspect everything.
    Personally, I broke the "air lock" in my main drain and water came back up within seconds to the pump basket. Everything else was closed, so blowing out the main drain again was no big deal. This shows that water can come back in the lines pretty quickly.
    14,700 gallons IG Pool Vinyl Liner - Octal Circulation System
    Hayward Pro-Series 350 LB. Sand Filter Model # S270T - 2" Plumping
    Hayward CL2002 Chlorinator - Hayward Super Pump 2 HP Model # k48m2n111
    Hayward AQR9 SWG 25K Salt Cell & TF-100 Test Kit + Speed Stir
    Gulfstream HE125RA - 117K BTU Heat Pump - Date of Build is 11-2013
    Jul 2014
    Connecticut
    1,215
    Catanzaro -- I thought OP meant gizmo was filled with water..
    Aug 2015
    macomb twp
    30
    So i got a shop vac and sucked out the water in the skimmer and the skimmer line. An antifreeze water mix came out at first. Then i started to see heavy heavy antifreeze coming out. So i stopped the vacuum and dumped more antifreeze in and put the skimmer gizmo back in. Will this process be ok?
    Jul 2016
    Nazareth PA
    14
    Why/How did the gizzmo come out?? My gizzmo screws into the bottom of the skimmer. Is there more than one type?
    IG Pool
    ~21000 gallons
    Vinyl liner
    Sand Filter
    12 hours a day Full Sun
    Catanzaro's Avatar
    Jul 2014
    2,203
    You should be fine with what you did? Please check the pump basket to see if there is any water in there.
    Next year, scrap the pool guys and close the pool yourself. Send me pictures from all different angles of your equipment and describe the returns, main drain and skimmer set up. I will be glad to help you close your own pool and save some money.
    brtims:
    The skimmer Gizmo was probably never installed properly and left out. I do not know any way this can come out. The fit is very tight.
    Aug 2015
    macomb twp
    30
    My guess is that he forgot to install it. Blew the lines out, put antifreeze in thenm and never installed the gizmo. I screwed it in tight so i know there is no way it could just come out. These guys are all in a hurry, that is the problem
    Jul 2014
    Connecticut
    1,215
    Yes sounds like somebody was in a hurry, if you cross thread a gizmo friction will hold it in & they pop out when skimmer filled with water as they are buoyant. Good catch / eye!
