Results 1 to 7 of 7
Thread: Replacing pool pump only.
    Jun 2016
    Augusta, GA
    9
    I have an emerson motor seen here
    Motor
    With a Hayward pump, the part with the viewing window and basket. Unfortunately the pump section has no serial or model number. It has a place for one but it is blank seen here
    Pump Plate
    The intake on the pump section is cracked
    and I am hoping to replace it without having to replace the motor since the motor works just fine.
    Here is the pump itself.
    Pump
    Is this possible? if not do you have any suggestions for a new unit that's not terribly expensive?
    mas985's Avatar
    Pleasanton, CA
    11,476
    Re: Replacing pool pump only.
    That is a Hayward SuperPump. More than likely it is the 1 HP.
    Is the pump housing cracked or is it the fitting that goes into the housing?
    Mark
    Jun 2016
    Augusta, GA
    9
    It is the section of housing around the fitting. I have put some pipe repair epoxy around it which has helped but I would like to replace it.
    mas985's Avatar
    Pleasanton, CA
    11,476
    Mark
    Jun 2016
    Augusta, GA
    9
    Yes it's 1 1/2 thank you so very much
    Hayward Pool's Avatar
    Oct 2014
    Elizabeth
    415
    I have decided that once in a while I will send out a part. If this guy private messages his address I will provide a new housing.
    Hayward Pool Tech
    80+ Years of Technologically Advanced Pool Product Manufacturing
    poolside@haywardnet.com
    Jun 2016
    Augusta, GA
    9
    That would be amazing. PM has been sent.
    ~9700 Gallons, In Ground with a Vinyl Liner installed 06/16
    Hayward Sand S160T with a Hayward pump
    Leslies Total Pool Care DPD test kit (came with pool)
    Filled from county water
