Thread: Should I put my pool robot in the pool when I am slamming it?
    Aug 2016
    Houston TX
    46
    I have recurring mustard algae and am about to SLAM my pool. Should I have my robot in the pool in order to sanitize any traces of algae that are on/in it? Or is there another method recommended to sanitize it?
    Houston, TX
    23K gal, chlorinated in ground irregular shaped white plaster pool with waterfall feature. DE filter. 1.5 hp Hayward super ll pump. Doheny Discovery Cleaner. TF-100 test kit.
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Re: Should I put my pool robot in the pool when I am slamming it?
    Brush, brush is the best thing to do while SLAMing. Every day. The whole pool. You'll get some great muscles in the process. Advil for any aches.
    When I first took over my pool and needed to SLAM, I did use my robot while doing so. As long as you're not overshooting your FC target by much, your robot will be fine. There is no replacement for manually brushing the pool though.
    Isolated Spa - 345 Gallons
    Aug 2016
    Houston TX
    46
    Thank you Joel. I will be sure to brush it! How long after you add chlorine should you be able to test to see what your levels are?
    Houston, TX
    30,287
    It's a varying value. When you start the SLAM, test about 4 times daily. Within a day or two, the FC consumption will slow down and you can begin to stretch your testing out. Twice daily is a good target number
    Mod Squad pooldv's Avatar
    DFW, TX
    24,201
    Add chlorine brush and retest in 15-20 minutes, pump running.
