Thread: Pump to remove water from the pool to the yard
    Oct 2016
    Bradenton, FL
    1
    Does anyone have a recommendation for a utility pump to move water from the pool out to the yard?
    We have had 5 days of heavy rain, (my trench drain is plugged with 15 years of yuck) plus Hurricane Matthew headed towards Florida, so I need a quick way to move water out to the yard.
    We plan on re-doing the entire pool this winter, but need a good solution now.
    Thanks!
    Jun 2014
    13,213
    Re: Pump to remove water from the pool to the yard
    Hello Joan and welcome to TFP! If your local hardware store doesn't provide rental pumps, you can shop locally or on-line at places like Harbor Freight or other such outlets for submersible pumps. You should be able to get a decent one with a good GPH capacity for under a $100. Here are a couple examples:
    Submersible Utility Pumps - Utility Pumps - Pumps - The Home Depot
    https://www.walmart.com/c/kp/submersible-pumps
    Submersible Pumps - Grainger Industrial Supply
    Submersible Utility Pumps | Water Pumps | Northern Tool + Equipment
    Hope that helps.
    mas985's Avatar
    Pleasanton, CA
    11,558
    Most pools have a way to directly drain using the pool pump. It will be either a spigot right after the pump or if you have a DE or sand filter with a multi-port filter, you can put the filter into waste mode which will direct the water to the waste port.
    Mark
    Jan 2012
    'burbs of Augusta, Georgia
    6,596
    And if all else fails, and you have a low spot in the yard to direct the water to- you can make a simple siphon using garden hose.
    Teald024's Avatar
    Aug 2016
    Columbus, Ohio
    841
    You don't mention the pool type in your post. If you fill your signature with pool info & model numbers and other info per the suggestions . It can help us easily identify what equipment you have installed.
    Back to your question. I have an above ground pool and just use the drain on the filter to drop the water level with gravity feed. I use a flat hose with a screw in connection on the end to take the water away from the pool area. I don't have to use the pump, gravity does all the work. Since I don't have a specific valve (yet) on the drain, I just shut off the valves on either side of the filter when I make the connection. Then open the valves and it comes a flowing out...
    Dave - Aqua Leader Elegance AGP 15'x30'x 54", 12k gallons, vinyl liner ... Hayward/SwimPro Voyager pump SW159412STL, 2hp, 2spd, Hayward/Voyager 175sf element filter SW175MDDVPAKS, Installed August 2016 ... Liquid Chlorine, Stenner, Woods 50015 timer ... TF-100 .... CYA/Chlorine Chart ... Recommended Levels ... Basic Care Schedule ... Extended-Test-Kit-Directions ... ABCs of Pool Water Chemistry
