Results 1 to 18 of 18
Thread: New build proposal in GA, would like some feedback
    Jul 2016
    Cumming, GA
    22
    All, I'd like some critique here on my purposed build; I've removed all the pricing as I'm not looking for that just if there's anything I need to add/subtract here. Also some thoughts on the draw-up from the PB. The fire-pots will be nixed due to cost, I can't justify the cost plus I have the fire-pit for "fire."
    Pool is 34 x 18’10”
    Pool Area: 500
    Deck Area: 975
    Avg Depth: 4.8
    Int. Area: 984.8
    Gallons: 18,000
    Depth (3'-6')
    Pool Specifications:
    Pool perimeter (per foot) 101
    Dig / Form Pool
    Dirt Haul if Necessary
    Plumbing:
    Sheer Descent (3)
    Sheer Descent Plumbing (3)
    Pool Base Plumbing Includes 30ft (1)
    Sunshelf Bubbler (1)
    Steel for Pool:
    Steel Pool 101
    Steel Extras (1)
    Shotcrete for Pool:
    Shotcrete 101
    Steps, Benches, Raised Beam (5)
    Electrical
    Electrical For Pool (1)
    Masonry:
    columns (2)
    Fire Pit Standard (1)
    Tile \ Coping
    Tile \ Coping (101)
    Stack Stone (35)
    Finger ledge (22)
    Decking
    Color scored concrete (975sq/ft)
    Grading drainage (1)
    Interior Finish:
    Pebble Finish (500 sq/ft)
    Pool Equipment:
    Jandy Pool Package (1)
    Jandy FHPM1.5 Flo Pro Pump, WFTR 80 Water Feature
    Pump 80GPM, Jandy CL460 Cartridge Filter, Fusion
    Nature2/Tab Feeder, Paramount UltraUV System, PF1102T
    Timer w/Freeze Protection, PX100 Transformer 100W, P-
    200B Water Bonding Fitting, Paramount Glow 3" Program
    Lights 100 ft Cord x 3, 9450 Robotic Cleaner
    Misc. \ Start Up Fees:
    Pole, Brush, Test Kit and Pool School (1)
    Startup \ Pool School (1)
    Erosion Control (1)
    YippeeSkippy's Avatar
    Jan 2012
    'burbs of Augusta, Georgia
    3,939
    Re: New build proposal in GA, would like some feedback
    Looks good....except lose the Nature2 and the UV system and go with a Salt Water Chlorine Generator (SWG). The Nature2 adds metals (copper, silver) to your water and will cause staining to your pool surface. Lots of folks regret this and come here for help after the fact. Save yourself that trouble!
    The UV system isn't needed in a residential outdoor pool- you've got a big hot Georgia sun shining its UV rays down on the pool and helping rid it of CCs. You still need chlorine with a UV system so....why bother buying it?
    Keep us posted with the build. Its going to be gorgeous!
    Yippee
    12K Fiberglass IG, Infinity 4000 automatic cover, SWCG, Hayward Sand Filter, Hayward 1.5 Pump, Savi Melody LED pool lights, outdoor speakers and other assorted doo-dads. Sundance Altamar Hot Tub. Our pool build--> Our Pool Solved Our Sloping Yard Skippy's Cheap Pool Cooler -->Skippy's New Fountain
    CLICK HERE to Become a TroubleFreePool.com Supporter
    GaryT58's Avatar
    Jul 2016
    Monroe, GA
    331
    Welcome! I would +1 the move to salt water system.
    I would suggest having at least one mount for umbrella. We have built in table with a mount for umbrella, so gives a nice area in pool under 10' umbrella for escaping the hot GA sun when relaxing in pool.
    38'x16' Fiberglass pool - 3.5' - 8' deep - 19,000 gallons. AutoPilot Total Control SWG (RC-52 cell), Pentair SuperFlo VS, Pentair SD70 Sand Filter, Coverstar Automatic Cover, 10' board, PAL Treo lighting, Polaris 9550 Sport robot, Lamotte ColorQ Pro 7 test kit.
    Isaac-1's Avatar
    SW Louisiana
    6,702
    What they said, but also upgrade to a 2 speed or variable speed pump to save on electricity (most of the variable speed pumps have basic built in timers, so that is another place to save money)
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    18,279
    What a awesome design! Look classic! This will be a fun one to watch.
    If you use the IMG code you can have the pics right in your thread.Makes it much easier for all to see.
    I would love to see a picture of where the pool is going.
    How many returns and where will they be located? Lights? Skimmer?
    TFP Moderator 33x52 round AG 25,600 gals Sand Filter 1.5hp Pump - 2 Speed, SLAM, Pool School, Recommended Levels, Recommended Chemicals, Pool Math, Chlorine/CYA Chart, TF-100 Test Kit, Become a TFP supporter!
    Jimrahbe's Avatar
    Jul 2014
    Bedford, TX
    1,440
    I agree with dumping the Nature2 and the UV system.. I have a SWG and love it, but you can also use a Stenner pump system.
    Since you are not getting the fire pits on the waterfall wall, I suggest that you have them run low voltage wiring to where the fire bowls are now. Not as fancy as a fire pit, but lighting would still look cool as an accent on the wall. If you don't get the wiring preinstalled, it will be much harder to do later.
    Finished in 2015 - 17K Gal, IG, 20' x 25' Almost Rectangular Pool, Pebble finish, three rockport water falls. Pentair Equipment: EasyTouch 4, IC40 SWG, 3 HP VS Pump, CCP5200 Cartridge Filter.
    TF100 with SpeedStir and SampleSizer, ColorQ Pro 7, Dolphin Premier Robot Cleaner, added Screen Logic 2.
    Jul 2016
    Cumming, GA
    22
    Quote Originally Posted by kimkats View Post
    According to the PB we would have two skimmers and three or for returns. The PB really does not like use a Salt-Clorinator (Salt system) and tells me that they'll install a Salt system but I'll have no warranty. Of course this is a red flag for me so I'm somewhat stuck; I like this PB and their work but they're really don't like salt systems.
    Jan 2012
    3,939
    Did he say *why* he doesn't like them? Like- "I don't make as much money off them as I do selling fairly useless UV and mineral systems"?
    The bottom line is all pools end up being "salt" pools, as chlorine is used it leaves behind slight salt residue. After a couple of years its measurable although it poses absolutely no problems to the pools.
    Jul 2016
    Cumming, GA
    22
    Quote Originally Posted by YippeeSkippy View Post
    Claims the salt causing issues with pumps and other components, also bad on the Pebbletec. Should I go with someone else over this?
    Jan 2012
    3,939
    He is wrong. There are millions of pools with Pebbletec and salt. You can always add salt later of course (especially if he leaves you room in the equipment pad plumbing) but you definitely want to avoid that mineral system as that is outright damaging to finishes and the UV system is just wasted money.
    Yippee
    JoyfulNoise's Avatar
    May 2015
    6,821
    If the PB doesn't want to install a salt system, then ask him to do a liquid chlorine dosing pump (Stenner pump). Or have install an inline puck chlorinator (which you will rarely use) and install a salt system after the fact.
    Look up "alternative sanitizers" in the search box and you'll find hundreds of threads on the subject. UV/mineral systems do not allow you to use any less chlorine despite the bogus sales claims. UV is a waste of money and minerals (copper ions) will eventually stain your plaster surface requiring a very costly chemical process to remove stains.
    I have had my salt pool, with concrete decking, flagstone coping, natural stone waterfall and PebbleTec finish running for years now. Not a single problem with any of the equipment or the pool materials. In short, the claims the PB is making about damage are scare-tactics to get you to buy at high cost to you, a cheap, high profit margin system from him.
    Finally, warranties are fairly worthless. The PBs warranty will cover major catastrophic defects in workmanship which almost never happen. Minor warranty repairs will be fought tooth & nail by the PB and his subs as warranty work is a money loser to them. They will blame you for everything that goes wrong as a way of weaseling out of the work. Finally, any warranty work you can get them to do will often only cover materials, you will still have to pay them for labor and labor cost will be the lion's share of the bill.
    How many quotes/PBs have you've gotten? If this is your first, put it on the shelf and keep looking.
    Matt
    16k IG PebbleTec pool, 650gal spa, spillway and waterfall, 3HP IntelliFlo VS / 1.5HP WhisperFlo, Pentair QuadDE-100 filter, IC40 SWCG, MasterTemp 400k BTU/hr NG heater, KreepyKrauly suction-side cleaner, EasyTouch controls, city water, K-1001, K-2006 and K-1766 test kits, Mannitol test for borates
    Jul 2016
    Cumming, GA
    22
    I have 5 quotes total, this PB is cheaper by a few K of the next one up. I'm meeting up with the owner on Saturday to discuss options, if I get any further red flags I'll move on. Shame, this outfit seems to have some great ideas with regards to design and the like.
    May 2015
    6,821
    See if they/he is willing to negotiate on his warranty. Perhaps he might be willing to warranty things like the coping so long as it's poured concrete and not natural stone. The equipment is usually warrantied by the manufacturer and none of them, as far as I know, have exclusions based on SWG use (most offer SWGs). So "being hard in the equipment" is a non-issue. PebbleTec is also warrantied through PebbleTec itself so if there were an issue with salt, they wouldn't certify installers to do it. Make sure that you are getting PebbleTec installed by a PebbleTec "Certified" installer.
    Matt
    Aug 2013
    Atlanta, GA
    2
    Is your pool builder a "she"? If so, I think I know which company you are talking about. We used them to build a few years ago and we are getting ready to start a new pool with them (we moved to a new house). Feel free to message me.
    GaryT58's Avatar
    Jul 2016
    Monroe, GA
    331
    Another thing to think about - I see you have a water fall feature, which is very nice. You may want to consider a fountain which you could optionally run at night. I wish I had installed this in mine here in Monroe, GA. I have full sun most of the day. Pool was getting up into the 90s at the peak of the summer. I bought a couple of fountains that I installed into returns at night, and this lowered the water temp to 82ish. Wish I had installed these into my pool deck with valve control so I could just turn on as needed. If your water falls are moving a lot of water then they may be sufficient.
    Aug 2014
    Houston tx
    2,313
    You could also get a larger filter. I have the Jandy 580 and my pool is only 10 k gal. Bigger is better for filters - less cleaning involved. Are you getting automation?
    Marla
    No longer living vicariously through other people's pool builds. Pool build is complete on my IG SWCG pool, approx 10,000 gallons. All Jandy equipment - VS 1.5 hp pump, 580 cartridge filter, AquaPure 1400 salt cell, AquaLink PDA system. Dolphin m500. PebbleSheen Blue Surf with shells and beads added. TF-100 w/ SpeedStir. A Houston Pool Build Inside the Loop
    Aug 2014
    Houston tx
    2,313
    Oh and I would go 3.5 for the shallow end. Make sure that it's water depth and not from the coping.
    Marla
    Jul 2016
    Cumming, GA
    22
    Quote Originally Posted by Marlahoutex View Post
    Very likely will do automation but it's not a must for us. It it makes it easier to maintain and isn't cost prohibitive.
