Results 1 to 8 of 8
Thread: Pump not priming
    Jun 2015
    Corinth/TX
    3
    Pump not priming
    My first post on this forum - I've got a Jandy Stealth 2HP pump, just over 1 year old, which I accidentally ran dry for several hours while at work a few months ago. The nearest skimmer had filled with leaves and debris following a storm. I turned off the pump, cleaned everything up, and restarted the pump after allowing it to cool down. It did still work, but since that event, it takes a long time to prime. A few times, I had to manually prime it to get it moving. As of a few days ago, it will no long prime at all. It doesn't draw water, even if I shut down all but one skimmer. However the pump motor does sound fine.
    While this sounds like a suction side leak to me, I'm curious if the previous event would have damaged the impeller? Tonight, I plan to open it up, clean out the impeller and see if there is anything restricting flow there. And, I've ordered a new basket O-ring. The one in place is just slightly twisted, but I don't know if it's enough to cause such a significant impact on water drawing.
    Anyone have further thoughts?
    Oct 2014
    Sacramento, CA
    72
    Re: Pump not priming
    Could be a damaged impeller.... first thing I would do is get a blow bag from a local supply store and force water through the skimmer into the pump and see if it grabs water then, also a good way to check for a suction leak is once you manually prime your pump run a garden hose over anything before the pump. i.e. unions 3-way/2way valves and the lid while its trying to prime that will tell you if you have a suction leak
    David Randolph
    Warranty Station
    Pentair
    Jandy
    Owner Sac Pool Pros
    Teald024's Avatar
    Aug 2016
    Columbus, Ohio
    1,000
    Since it still "kinda" worked after the run dry event, I'd say it is likely the diffuser or the gasket between diffuser & housing. It was probably damaged while running dry and kept getting worse since then. Eventually not priming at all.
    Dave - Aqua Leader Elegance AGP 15'x30'x 54", 12k gallons, vinyl liner ... Hayward/SwimPro Voyager pump SW159412STL, 2hp, 2spd, Hayward/Voyager 175sf element filter SW175MDDVPAKS, Installed August 2016 ... Liquid Chlorine, Stenner, Woods 50015 timer ... TF-100 .... CYA/Chlorine Chart ... Recommended Levels ... Basic Care Schedule ... Extended-Test-Kit-Directions ... ABCs of Pool Water Chemistry
    Oct 2014
    Mishawaka, IN
    4
    If the motor still sounds fine it sounds like a gasket issue to me, especially given that it has continued to deteriorate since then. I have been amazed in the past how much difference a new gasket (or two or three) can make. I had a little $0.80 o-ring that was causing my system to lose prime.. sounds like a suction leak to me.
    Overspending on pool chemicals since 2010.
    30,297
    Always check the most obvious issue......a suction side leak.
    SacPoolPro, what is a blow bag?
    Jun 2015
    Corinth/TX
    3
    Thanks for all of the great suggestions. It was a suction side leak. First, I got a bladder (blow bag) from Lowe's. It attaches to the end of a garden hose, fits into the skimmer hole, inflates with water to seal it and forces water through the open valve to fill the filter basket at the pump. I wanted to be sure I didn't have any blockage (I didn't). But it still wouldn't prime. I cleaned the impeller, but there was nothing to unclog. Step 3 - I inspected the basket lid O-ring a little more closely and decided that the slight twist might be causing a leak. I took out the O-ring, lubed it, flipped it over so that smooth side will make contact when tightened down, and closed the lid - tightly. And,....it works perfectly. I guess the most obvious some times really is the answer! I ordered a new O-ring to keep ready for the next time I see this. Good learning experience! Thanks for the advice!
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    My mother-in-law? :rimshot:
    Glad you found the problem Djones! Those easy, cheap fixes are always appreciated on a pool.
    Isolated Spa - 345 Gallons
    30,297
