Page 1 of 2 12 LastLast
Results 1 to 20 of 26
Thread: Wanted to share the dome I build
    Oct 2016
    Suffield CT
    6
    Just wanted to post some pictures of the dome I build over my 15x30 pool. I have a lot of tress so did not want to use the traditional closing method. In spring my plan is to raise the dome by 3 feet and cover it with clear vinyl.
    15'x30'x52" above ground pool
    Jun 2014
    10,904
    Re: Wnated to share the dome I build
    Nice!
    Aug 2016
    Pittsburgh PA
    195
    That's awesome! My last pool was above ground and no matter how hard I tried, I could not get pillows to keep rain water and leaves off the cover. It was a constant battle of draining that slimy stinky water off the cover - usually in the middle of the winter. Starting syphon from a hose with ice in it. Just sucked!
    Your solution is the best I've seen yet! Great idea and that will definitely keep the water and leaves off the cover.
    Sep 2013
    Connecticut
    728
    Also in CT... I will be curious to see if your structure sheds the snow, or whether it takes the other path. How are you stabilizing those arches running side to side on the pool?
    Interesting idea! I certainly wish you the best, and hope you will report back, one way or the other.
    18' x 48" ring top pool (Summer Escapes); 5500 gallons; set up June - October, stored during winter; Intex 2500 gph pump (B size cartridge filter) Hayward 21" sand filter + 1.5 hp single speed Powerflo Matrix pump (upgrade October 2016) *** K-2006 test kit, refills from tftestkits
    pabeader's Avatar
    May 2015
    Dallas Ga
    3,250
    Would love to see close ups of the different connection points. How does it attach to the pool?
    Bob - Palm Beach by San Juan Pools. approx 5000 gals Pentair 320 cartridge filter (all new guts installed by me) Goldline SWG Intermec 104 TImer Test kit: TF-100 w/Speed Stir
    28,865
    Ice? Wet Snow?
    Dave S. - Forum owner
    Sep 2013
    Connecticut
    728
    Wind?
    In the photo, as shown, there appear to be a few gaps along the edge of the pool. I think those might be problematic if they remain open.
    Oct 2016
    Suffield CT
    6
    Thanks for noticing that. I will be hanging more one gallon containers to cover those gaps. Need to find some.
    Hi pabeader. As I am new to this forum I could not figure out how to add more pictures. I will try to add more pictures. 2016-10-02 17.45.16.jpg
    GaryT58's Avatar
    Jul 2016
    Monroe, GA
    477
    Re: Wanted to share the dome I build
    Very cool!
    38'x16' Fiberglass pool - 3.5' - 8' deep - 19,000 gallons. AutoPilot Total Control SWG (RC-52 cell), Pentair SuperFlo VS, Pentair SD70 Sand Filter, Coverstar Automatic Cover, 10' board, PAL Treo lighting, Polaris 9550 Sport robot, Lamotte ColorQ Pro 7 test kit.
    Jun 2014
    10,904
    imamol, I've used those same products for miscellaneous projects around the yard. Conduit attachments I believe from the electrical section right?
    For posting pics, have you tried linking your photos from Photobucket? That's what many of us do here on TFP. Upload your pics to Photobucket (free), then copy & paste the IMG code for that pic from Photobucket to your TFP post. Works great.
    pabeader's Avatar
    May 2015
    Dallas Ga
    3,250
    Conduit! I like that. I was thinking PVC and wondering how it would keep from drooping...
    RyanMcC's Avatar
    Aug 2013
    NH
    210
    I was afraid of PVC too. That looks great!
    "...chemistry is not an exact science" -Mario Andrada, Rio 2016 Olympics spokesman
    21' x 52" Radiant Metric Round ~10K gal AGP with Hayward S180t pump/sand filter.
    Caldera (Watkins) Martinique 340 gallon installed in basement, Bromine and ozone.
    Taylor K-2006 test kit.
    pabeader's Avatar
    May 2015
    Dallas Ga
    3,250
    imamol - That picture was exactly what I needed. Now I've a new project for this weekend!!
    Sep 2013
    Connecticut
    728
    I also was thinking PVC - it looked white in the original photo. I will change my bet on behavior under load, now that I see the conduit
    Still curious how you are stabilizing the arches? The lengthwise elements are hard to see in the picture.
    Teald024's Avatar
    Aug 2016
    Columbus, Ohio
    94
    I would be interested to see how it holds up under weather & snow loads. Arches are strong and can handle the weight as long as the ends are fixed. Is that wire connecting each end of the arch horizontally? I would make sure those arch ends cant move!
    Do you plan to swim under the clear poly after you raise it? Or what is the point of going clear poly in the Spring?
    I hope it doesn't end up like this! They forgot to support the ends of the arches.
    Aqua Leader Elegance AGP 15'x30'x 54", 12k gallons, vinyl J-hook liner ... Hayward/SwimPro Voyager pump SW159412STL, 2hp, 2spd, Hayward/Voyager 175sf element filter SW175MDDVPAKS, Installed August 2016 ... Liquid Chlorine... ...TF-100....CYA/Chlorine Chart...Recommended Levels... Basic Care Schedule...Extended-Test-Kit-Directions
    Oct 2016
    Suffield CT
    6
    Quote Originally Posted by singingpond View Post
    I have galvanized wires (6 total) holding the arches width wise. This way the arch will be able to take up the load and not collapse. I thought of attaching it to the pool but did not wanted to drill holes in the pool top metal plate.
    Oct 2016
    Suffield CT
    6
    Trying Texas splash advice to use photobucket to add more pictures.
    Jun 2014
    10,904
    Nice!
    Oct 2016
    Suffield CT
    6
    [QUOTE=Teald024;1144264]I would be interested to see how it holds up under weather & snow loads. Arches are strong and can handle the weight as long as the ends are fixed. Is that wire connecting each end of the arch horizontally? I would make sure those arch ends cant move!
    Yes, my plan is to keep the cover up all summer after I change it to clear vinyl. Due to trees, my pool does not get that much sun so I want to use the green house effect to keep the water warm. I dont like to manage bubble solar cover either.
    Yes there is wire connecting each end of the arch. I am planning to keep the dome free of snow as much as possible.
    Quote Originally Posted by pabeader View Post
    Please let me know how it goes.
  20. Back To Top    #20
    Sep 2013
    Connecticut
    728
    So the whole structure is resting on the pool edge, but not actually attached to the pool?
