Thread: OK I'm back and armed with numbers!
    Sep 2016
    UK
    4
    My post 1st a few weeks ago, UK pool Owner What is this??
    was absolutely rubbish without full test data, well the test mentioned was quite expensive and difficult to get hold of here in the UK, so i went more expensive
    I now have a Lamotte ColorQ7
    Not done a thing with the pool since my 1st post so here is the data I collected tonight:
    Inground outdoor Pool of approx.20,000 gallons
    Test results
    FC 4.18
    TC 4.62
    PH 7.5
    ALK 94
    CH 576
    CYA 56
    According to Lamotte/me
    FC and Tc are high which I can see
    PH is good
    TA OK
    CH to high
    CA OK
    so guys looking for your thought on what the stuff is I keep getting at the bottom of pool
    Cheers
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    15,001
    Re: OK I'm back and armed with numbers!
    Chlorine levels aren't that high really. What does this stuff at the bottom of your pool look like? Can you describe it?
    Essential Links:
    Sep 2016
    UK
    4
    Quote Originally Posted by Patrick_B View Post
    You clink my first post in the post above, photo's there of the stuff
    kellyfair's Avatar
    Jun 2016
    Tampa, FL
    173
    Duraleigh in your other post gave you the best answer. That is algae, and with a CYA of approximately 60, you don't have enough chlorine in your pool. See this chart, to understand relationship between FC and CYA, and read through these instructions on how to slam your pool.
    Kelly, Tampa FL
    15' by 4' Intex above ground metal frame, about 5300 gallons
    Intex 120V Krystal Clear Sand Filter Pump & Saltwater System CG-28679 with E.C.O.
    TF100 Kit and Speedstir
    Intex Auto Cleaner - works great!
