Thread: Remove diving board
    Mar 2016
    Easley, SC
    372
    Remove diving board
    I was wondering if its good practice to remove the diving board for winter? If so, do you also remove the base each time? I currently have mine removed as its new to me and wanted to check for any damage on the underside of the board and inside the base. I coated the bolts with a heavy amount of water proof grease since they are totally exposed but would this be a good idea to do every winter or should I leave the base attached? Will the base fill with water and cause the bolts to rust even more if not removed?
    18x36 inground / 28k gal / Phanton vinyl liner (replaced in 2009) / Hayward Pro Series sand filter / Hayward 1hp pool pump / Hayward 3/4hp booster pump
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Re: Remove diving board
    If you are able to remove the diving board for the winter, I would do so. Less likely for the diving board to get corrosion or more weather wear. I would remove it at the base if possible and store in a covered, dry place. Mine stays in place mostly because when I took over the pool, it was badly rusted in place. I have a feeling that if I tried to remove it, I'd be creating a new project of remounting the diving board to the deck... which I may do next spring anyway.
    Isolated Spa - 345 Gallons
    Mar 2016
    Easley, SC
    372
    So you think removing the base is good practice? I have read mixed reviews but no one has proven either way is better. I also need to figure out how to coat the base bolts when the base is installed to help prevent them from rusting again. I may make some caps out of PVC and fill them with grease and install over the bolts. I could do this when the base is installed and when its removed for winter.
    Feb 2014
    Central Minnesota
    5,080
    There are many places to find bolt caps in the right size. I know they're not the cheapest place around but a search on Grainger Screw Caps - Screws - Grainger Industrial Supply produces quite a few, in quantities larger than you need... You may be able to find some at a local hardware store. Keeping the bolts coated and lubricated is likely more important than removing the base.
    Mar 2016
    Easley, SC
    372
    Thanks for the help and the link. I will search locally and see what I can find.
