Thread: To cover or not to cover for closing - SC
    Sep 2016
    Clover, SC
    129
    New (1.5 months to be exact) to owning a pool for those of you who didn't go through our grass green water with us (thread: clueless newbie) This will be our first winter with the pool.
    We live in SC and have mild winters, our pool is in the open ie; no trees, so very little if any debri falls into the pool. Do we cover or leave it uncovered over the winter?
    24' round above ground - 13,500 gal
    sand filter - TF-100 - 1.5 hp pump
    We live outside of city limits and water costs are doubled
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Re: To cover or not to cover for closing - SC
    Are you actually going to close the pool (ie- blow out lines and equipment) or are you simply going to maintain it dormant? Covering the pool in either case will decrease your chlorine loss by a significant amount and keep any debris out, even if it's minimal.
    Isolated Spa - 345 Gallons
    Alwayswantedapool's Avatar
    Jun 2015
    York SC
    201
    Hi Staci, I am just down the road from you in York sc. Last year was my first year with a pool and I did not close it. The nights that the temp dropped below freezing I would run the pump to prevent any pipe issues and would add chlorine once a week. That's was it..
    Mark, Pool: 30,000 gallon, IG Vinyl, Pentair Superflo Variable Speed 1.5 HP pump, Hayward S220T Sand Filter, Taylor k-2006 Test kit with speedstir. Dolphin Nautilus Plus.
    Hot Tub: Hot Spring Grandee 450 Gallons, Ace System (Salt water Chlorine Generator) Dichlor / Bleach method. Taylor K1766 Salt Test.
    30,493
    I would suggest not closing a pool in all but the very coldest elevations of South Carolina. Simply leave the pool open as always. You will see SIGNIFICANTLY less chlorine loss. Just keep the debris out and you will be up and running when the temps are warm enough.
    Sep 2016
    Clover, SC
    129
    [QUOTE=Alwayswantedapool;1143771]Hi Staci, I am just down the road from you in York sc. Last year was my first year with a pool and I did not close it. The nights that the temp dropped below freezing I would run the pump to prevent any pipe issues and would add chlorine once a week. That's was it..
    Sent from my SM-T807V using Tapatalk[/QUOTE
    perfect thanks guys
    As long as you don't have to worry about kids, yours or those in the neighborhood, getting into the pool, leaving it uncovered will be much better for the chlorine loss as stated above. Since I see that the cost of water is super expensive and a concern for you, keeping it open will also allow for the rain to replace most if not all of any loss from evaporation. Lucky for those of you who are not in the desert like me.
