Results 1 to 9 of 9
Thread: Maytronics Dolphin - 4 ppm chlorine?
    ned8377's Avatar
    Apr 2015
    Wake Forest, NC
    239
    Maytronics recommends 4 ppm chlorine when using their equipment in a pool. Does this mean 4 ppm with no CYA or with CYA? Anyone have any experience with this. Need help with clarification since 4 ppm for me, with CYA, is the bare minimum.
    True L 45,000 gal Hayward IG vinyl pool. Hayward Tristar 2.40 THP; 1.5 FRHP/1.60 SF. Hayward Model # S310T2 Sand Filter. Aqua Rite T-15. Aqua Comfort 154,000 BTU Heat Pump. TF-100
    JoyfulNoise's Avatar
    May 2015
    12,874
    It's just standard industry boiler plate regarding FC levels. The pool industry quotes 2-4ppm FC without regard to any CYA level as appropriate.
    The TFP Recommended levels do take into account CYA and the TFP levels are much gentler than what the pool industry recommends.
    Matt
    ned8377's Avatar
    Apr 2015
    Wake Forest, NC
    239
    Re: Maytronics Dolphin - 4 ppm chlorine?
    Thanks JoyfulNoise. So if my CYA is around 50 then 8 ppm FC would be ok right?
    May 2015
    12,874
    Quote Originally Posted by ned8377 View Post
    Do you routinely keep your FC that high? 8ppm FC with a 50ppm CYA is a 16% FC/CYA ratio...that's a little less than half shock levels and what one would keep a pool at if mustard algae was a recurring problem. Do you have problems with mustard/yellow algae?
    The cleaner will be fine but I could easily see the plastic parts of the cleaner fading (especially anything with blue dye in it) over time as that is a fairly high chlorine exposure.
    Matt
    ned8377's Avatar
    Apr 2015
    Wake Forest, NC
    239
    I had not turned my salt generator down yet and we've had some cloudy days so my chlorine has crept up. Anyway, pool math says that for my pool SWG Minimum: 2, non-SWG Minimum: 4, Daily Target: 6 to 8. Actually, what does the daily target mean? Is that what you would aim for if a person added chlorine every night and then it would drop down to 4 by the next evening? Thanks.
    May 2015
    12,874
    Your CYA is rather low for an SWG pool. TFP recommends a CYA of no lower than 60ppm with 70-80ppm the preferred level.
    Your numbers are ok. Usually with an SWG you try target your run times to keep your FC near the target levels so you end the day no lower than your minimum value. You shouldn't really need more than 6ppm FC in your pool unless your experiencing high FC loss.
    Matt
    smforte's Avatar
    Sep 2013
    Montgomery,Al
    668
    Have had my Dolphin for 4 months. Keep my FC at 6. Accidentally left my dolphin in overnight and the blue faded some. Other than that, it works great.
    Montgomery, AL
    27000 16 x 36 IG, Vinyl, Grecian, Hayward Sand filter, 1 HP Pentair whisperflo motor, Aqua Genie filter not by choice, no extra jets, Dolphin s300i robotic cleaner,Taylor K 2006 test kit, speed-stir which I couldn't live without!
    ned8377's Avatar
    Apr 2015
    Wake Forest, NC
    239
    Thanks everyone.
    Dec 2014
    Riverside California
    481
    My FC is around 6ppm because my CYA is 50. I pull my Triton Plus out of the water and hose off the pool water after each use. Can't see damaging an expensive tool for no good reason.
    38000 Gal, IG, Plaster, 20' x 40' x 10', Attached Raised Spa, Intelliflo VS 3 HP (011018), Pentair Quad DE 60 Filter, Raypak (Rheem) 400,000 BTU (407a low Nox), Easy Touch 8 upgrade, Screenlogic 2 with wireless, IS-4 Spa Side Remote, Stenner 45MPHP10 w/15 gal tank, Intellibrite 5g (3), Dolphin Triton Plus robot with PRO remote, Water Tech Catfish handheld vacuum for spa, TF100 with SpeedStir.
