Page 1 of 2 12 LastLast
Results 1 to 20 of 28
Thread: First Time Posting
    Jun 2015
    Oviedo, fl
    18
    First Time Posting
    Hello All,
    We finally have a new pool in the ground. We starting with permitting back in October and it has now been 30 days with water. This weekend is the first that the pool maintenance company turned it over to us. This is our second pool, our first was many years ago and my husband took care of it. He's not well, so this one is on me. I have been reading everything on here, but it takes me a few times for things to click...I thought it was going to be fairly easy, but, for me, it's not. I tried several times to put the numbers in PoolMath, but I had to have my husband help me do the tests today. I was out brushing the pool today and the waterline tiles felt rough. I looked at the salt numbers and they were at 4300 - way over. I told my husband and he told me the pool guy said to keep it high because of all the rain. We did the tests and here are the numbers: Cl 5; Ph 8.2; FC 4; CC .5; Calcium hardness 3750 plus, TA 50; CYA 22. I added 9 oz. of muriatic acid, drained some pool water and added new water. I haven't retested yet. Oh, and I can never get the black dot to disappear and I've done it many times - so frustrating. I've attached a picture - the water looks great, I just hope nothing is ruined with these terrible numbers. Thanks for any and all advice. I've so enjoyed reading everyone's posts and am happy to be a member of this group. I'm just sorry I had to ask for help so soon!
    Karen
    10,000 gal., Hayward Aqua Plus, Hayward DE filter, Hayward Max Flo VS, Aqua Blue Stonescapes, SWG T-15, TF100 Test Kit
    Jun 2014
    13,181
    Re: First Time Posting
    Hi Karen and welcome to TFP! Let's start with two things ... your CYA and CH tests. For the CYA, you want a minimum CYA of "70" for optimum FC protection for your SWG. Your SWG produces FC slowly and continuously, so the higher CYA is essential. So you'll want to increase CYA with stabilizer using our sock-soaking method as soon as you can. This is assuming there is NO algae or cloudiness correct? As for your CH, I suspect that may be a testing error. Double-check your CH testing process by using the Pool School - Calcium Hardness page. Please report back your CH number.
    It's good you caught the elevated pH. Try to keep that around 7.5 or so for now, and never let it rise over 7.8. Let's start with that and once you report back we'll be glad to help. Many eyes will be watching your thread I'm sure. Welcome!
    Oh, for your CYA test:
    Proper lighting is critical for the CYA test, so you want to test for CYA outside on a bright sunny day. Taylor recommends standing outside with your back to the sun and the view tube in the shade of your body. Use the mixing bottle to combine/gently mix the required amounts of pool water and R-0013 reagent, let sit for 30 seconds, then gently mix again. Then, while holding the skinny tube with the black dot at waist level, begin squirting the mixed solution into the skinny tube. Watch the black dot until it completely disappears. Once it disappears, record the CYA reading. After the first test, you can pour the mixed solution from the skinny view tube back to the mixing bottle, shake, and do the same test a second, third, or fourth time to instill consistency in your technique, become more comfortable with the testing, and validate the CYA reading.
    Jun 2015
    Oviedo, fl
    18
    Thanks Pat, will do.
    Jun 2014
    13,181
    Something else I just noticed in your numbers ... chlorine. You say "CL 5, FC 4, and CC .5". But remember .. TC = FC + CC, so your numbers only result in a total CL of 4.5. We never want CC over .5 or that might indicate a problem with excessive organics (algae), so it would be good to be sure about the FC and CC number before you add any stabilizer. We definitely want to rule-out any algae or an algae bloom in the early stages.
    By the way .... thanks for being a TFP supporter!
    Mod Squad Jimrahbe's Avatar
    Jul 2014
    Bedford, TX
    5,570
    Karen,
    Welcome to TFP, it is great place to be!!
    You should take a deep breath and relax and have fun with your new pool. Most chemical imbalances do not cause immediate and irreversible problems. It often takes a long time for them to become a real issue.
    That is not to say you shouldn't fix it when you find it, but the world will not end if you wait a day.
    If you can do we a favor, I'd appreciate it.. When you "post your numbers," please use the following format. It helps us to easily see everything at once..
    FC
    CC
    pH
    TA
    CH
    CYA
    Thanks a bunch..
    Jun 2015
    Oviedo, fl
    18
    I can't add either - FC was 4 and CC was .5 = 4.5. Thanks for catching that. My pleasure being a supporter.
    Will do, thanks Jim R.
    Aug 2014
    Northern IL
    4,615
    Did you retest the CH?
    Jun 2015
    Oviedo, fl
    18
    Not yet. I may have to wait until tomorrow after work.
    Isaac-1's Avatar
    SW Louisiana
    6,711
    These guys seem to have things in well in hand, so I just wanted to say I love how your pool wraps around the corner of the house
    Jun 2015
    Oviedo, fl
    18
    Thanks very much. We didn't have much room so we did the best we could do
    Jun 2015
    Oviedo, fl
    18
    Hi all,
    You were right Marian, I did the CH test wrong - it's 625. I stopped and picked up some CYA and put 2 lbs. in a sock and put it in the skimmer basket and squeezed it after about an hour. Will squeeze it again before I go to bed..that doesn't sound right. I added 600 ml of muriatic acid and noticed that the salt level has gone down to 3900. The Ph is still off the charts. Is there anything else I should do right now (please say no). I hope I can get the hang of this. It's just a bunch of numbers right now that I will follow, but I'm hoping they make sense to me at some point. I can't seem to get organized either and I'm a fairly organized person. I've had the Pool School notes copied and in a binder for several months now, but I seem to keep looking at different places for answers.
    Hi all,
    You were right Marian, I did the CH test wrong - it's 625. I stopped and picked up some CYA and put 2 lbs. in a sock and put it in the skimmer basket and squeezed it after about an hour. Will squeeze it again before I go to bed..that doesn't sound right. I added 600 ml of muriatic acid and noticed that the salt level has gone down to 3900. The Ph is still off the charts. Is there anything else I should do right now (please say no). I hope I can get the hang of this. It's just a bunch of numbers right now that I will follow, but I'm hoping they make sense to me at some point. I can't seem to get organized either and I'm a fairly organized person. I've had the Pool School notes copied and in a binder for several months now, but I seem to keep looking at different places for answers. Also, that black dot never disappears.
    Aug 2014
    Northern IL
    4,615
    Before we say no.... did you check the pH at least a half hour after the add? If so, what is it?
    You will get this. All of a sudden it will all make sense. Honest.
    and... Hahaha about squeezing before bed!
    Jun 2015
    Oviedo, fl
    18
    yes, it was the highest it could be 8.2. I think if there was a higher number on the test, it would be even higher.
    Aug 2014
    Northern IL
    4,615
    Do you have more MA on hand? Are you using the 31.45%?
    Jun 2015
    Oviedo, fl
    18
    yes and yes - am at work and will check ph when I get home tonight - thank you.
    Jun 2015
    Oviedo, fl
    18
    ok, just got home and tested pH and it's the highest level on the T-100, added 600 ml muriatic acid and squeezed the sock - guess I will wait 30 mins. or so and test again?
    Aug 2014
    Northern IL
    4,615
    Sounds like a good plan.
    Jun 2015
    Oviedo, fl
    18
    ok thanks
    Aug 2014
    Northern IL
    4,615
    How's it going?
  20. Back To Top    #20
    Jun 2015
    Oviedo, fl
    18
    I just did the pH test again and it looks like 8.2 - maybe it's coming down. Do you think I should add more MA tonight or wait and test again tom. night?
