Results 1 to 7 of 7
Thread: No bubbles out of one return
    Jun 2016
    Austin, TX
    191
    I have an attached/raised spa. It has 4 returns in a semicircle on one side and only one return on the other where to waterfall is. The lone return is much lower flow and also no bubbles come on when I turn the blower on. Is this how it's supposed to act? It's a new pool to me and I just replaced the blower. Thanks for the help.
    13k Gallon IG Pebble w/ attached Spa, AquaRite T-Cell-15 SWG, Hayward DE6020 Filter, Hayward 2 HP Pump, Hayward 400k Heater, TF-100 Kit, Pool Logger
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    4,562
    Re: No bubbles out of one return
    If that return is linked to the waterfall, it may be designed not to have bubbles/aeration as you don't really want bubbles going through the waterfall. Can you determine if the waterfall is on it's own return, not in the loop with the blower and if perhaps that one return is as well?
    Isolated Spa - 345 Gallons
    Jun 2016
    Austin, TX
    191
    Sorry, maybe I made it sounds like it was linked to the waterfall. I just meant that is is over on the side with the spillover. It's really weird, maybe that lone return is plumbed with the pool somehow and not the spa...no idea why it would flow water but not air when I turn the blower on. That return is very much about the same flow as the pool returns whereas the other returns in the spa have a much higher flow rate.
    Mod Squad pooldv's Avatar
    DFW, TX
    16,917
    Sounds like it might be a recirculation return for moving water from the pool to the spa and out of the overflow back to the pool.
    Jun 2016
    Austin, TX
    191
    OK, yeah. you might be right. Trying to figure out how to test that. if I set my pool to spa only no water should come out of then, right? but it does. Trying to think about how my plumbing is set up and how it would let that happen. hmmm.
    Jun 2016
    Austin, TX
    191
    While in pool mode last night i closed off the valve to the pool returns and verified they were off, then checked that return, still flowing. Any ideas on what else to check?
    DFW, TX
    16,917
    No, I don't know. Maybe a pic of the equipment pad will help.
