Thread: Light No Longer Flush....Leaking Water
    sheree202's Avatar
    Jan 2016
    Lawrenceville, GA
    245
    I'm trying to figure out how to fix this problem. It was just installed a month ago.
    18 x 38 gunite, 39-7 deep, 8 x 12 tanning ledge with 8 deep water, umbrella sleeve, 2 LED bubblers.
    2 Pentair LED lights, 16 long fiberglass hill slide and jump rock. Sand dune pavers/coping. TF-100. My build: Georgia Pool Build.... No Longer O/B :))
    Jun 2014
    13,213
    Re: Light No Longer Flush....Leaking Water
    This should definitely still be under warranty. I'd call that installer right away or first-thing tomorrow morning and have them secure that light back into its niche.
    Mod Squad Jimrahbe's Avatar
    Jul 2014
    Bedford, TX
    5,608
    Sheree,
    I agree with Pat, should be a simple fix. But, to put your mind at rest, this will not cause a leak. The light itself is in a sealed assembly, but the area behind it is always flooded with pool water.
