Thread: First year closing with tfp
    Apr 2016
    Moundsville wv
    54
    I'm reading little on polyquat and how it's used. My pool has been balanced this entire Summer and I wasn't going to shut it down till around October however, I wanted to be aware of things that I wasn't last year and I certainly won't be buying no closing chemicals. So, how many users have had good luck with this? Is it needed? What if I just bring my fc to shock and then close?
    2015 built myself~15x30x52(15k)AG,vinyl liner~Hayward166t (16'' sand filter w1 Hp pump) Hayward sp1580 power-flo lx series~taylor2006 test kit
    Messman750's Avatar
    Jun 2015
    Groton New York
    34
    Re: First year closing with tfp
    I bring my FC to shock level the day before closing. I do not use polyquat 60. People use it for extra insurance against algae. If you close the pool with water temperatures below 60 consistently you should not need this algaecide.
    32x16 inground chlorine. 23000 gallon with diving board
    vinyl liner 1hp hayward super pump. Waterway sand filter new in 2014.
    maytronics dolphin m200 robot. I live in central NY.
    TF100 kit Taylor speedstir. Sonos audio
    Catanzaro's Avatar
    Jul 2014
    Monmouth County, New Jersey
    2,203
    People have had success with PolyQuat 60 and also without PolyQuat 60. Then again, people have opened up a green pool, even with PolyQuat. Personally, I believe the key is to close when the water temperature is around 60* and open around the same time, that is close late and open early. I closed my pool the last week of September and used PolyQuat in the event temperatures climbed back up. The temperature here in NJ is now cold enough to stall algae, etc.
    14,700 gallons IG Pool Vinyl Liner - Octal Circulation System
    Hayward Pro-Series 350 LB. Sand Filter Model # S270T - 2" Plumping
    Hayward CL2002 Chlorinator - Hayward Super Pump 2 HP Model # k48m2n111
    Hayward AQR9 SWG 25K Salt Cell & TF-100 Test Kit + Speed Stir
    Gulfstream HE125RA - 117K BTU Heat Pump - Date of Build is 11-2013
