Thread: first time closing a pool
    May 2013
    Chicago Il
    This is my first time closing a pool for the winter. I added all the closing chemicals. dropped about 3-4 in below skimmer. put air pillow in and put cover on. just wondering if it looks okay. It seems that most pics i see of other peoples doesnt seem that the cover sits so low in the pool
    new to permanent pool used to set up temporary intex pools every year
    15ft round
    hayward 1-1/2 hp cartridge filter/pump
    using vision pro mineral cartridge that came with it for now
    Re: first time closing a pool
    Those pics are hard to look at being sideways. I am new to most of this but I am pretty sure you need more pillows in there with the cover pulled tighter. From what I have read the cover shouldn't be in contact with the water. I am closing mine today myself. Last year I used one pillow on an 18' pool. This year I am adding another so I will have 2 4x4' pillows. I use chlorine bottles filled with water and rv antifreeze to weight down the cover all the way around (tied to the cover). I am also going to add a leaf net this year so I can keep the leaves removed until they all fall. It was nasty this spring and almost ruined my cover. Good Luck!
    Dennis in Central Indiana
    Pool owner for 4 seasons. 18 x 52 (7000 gallons) Intex Metal Frame pool. Hayward S210T93S Sand Filter and Pump (1 1/2 HP) w/ in wall skimmer. Taylor K2006 test kit w/speed stir.
    What is TFPC? Pool School Chlorine/CYA Chart Pool Math Recommended Test Kits
