Thread: White plastic turned orange ??
    Captain 776's Avatar
    May 2016
    Thailand
    146
    After I bought my Taylor test kit to test all parameters, it required I add large amounts of Calcium Chloride and Baking Soda plus CYA to bring all parameters to balance, but one of them or the combination of what I added, put an orange film on all the white plastic surfaces, like on the light frames and skimmer.
    it came off very easily with Muriatic Acid and a sponge, but can anyone tell me why those surfaces turned orange?
    Bruce
    8M x 4M X 2M no slope IG CONCRETE w/ceramic glass tile
    17,000 Gal EMAUX SWG JAZZI FILTER W/1-3 mm glass media, Jazzi Multi-port valve with
    T-750 filter w/ glass media
    1 main drain sump -3 returns - 1 skimmer
    Kokido digital salinity tester, Kokida drops for CL Hanna digital PH meter, Taylor K-2006
    Mod Squad pooldv's Avatar
    DFW, TX
    23,999
    Re: White plastic turned orange ??
    Sounds like it could be iron stains. None of those pool chems together or separately would cause orange stains. Raising pH and/or FC can cause iron in the water to stain. And plastic and fiberglass parts tend to show iron stains first. Vit C/ascorbic acid will remove iron stains also.
    May 2016
    Thailand
    146
    Great, thanks for your answer DV. It wasn't a big deal but I was concerned when I first saw it, but like I said, came off easily
    Bruce
