Results 1 to 9 of 9
Thread: Stenner Tank holding rain water
    asquare's Avatar
    Sep 2016
    Lake Mary, FL
    17
    I just installed my Stenner pump and tank and still tuning the dosage. I however have a question. The Stenner tank has a small reservoir area below the pump (there is a lip that goes around the flat top of the container). When it rains, this area fills with rain water. Do others face the same problem? How did you address it? I was thinking of just tilting the tank so that water would just accumulate in a smaller part of the reservoir but it does not resolve the issue. I don't like the idea of putting a plastic cover over the pump.
    16,600 gallon, midnight blue gunnite in-ground pool with attached spa, Hayward Ecostar 3400VSP variable speed pump, Jandy Aqualink 6100 panel, Blue Haven 450 Filter, HiTec solar panels, Stenner 45MPHP10 connected to Jandy panel for chlorination, Jandy Lite2 Model LJ propane gas heater, Polaris 360, TF Test Kits
    Jaimslaw's Avatar
    Jun 2015
    San Diego, CA
    299
    Re: Stenner Tank holding rain water
    You can drill a hole through that "lip" - ie penetrating both sides of the tank, and then insert a 1/4 drain tube through the tank to let water out that way. Hole would be drilled a hair above the tank surface and the tube cut flush at each drill point (lubed up with silicon). Then place a spacer underneath the bottom edge to give it a little gravity drain effect/tilt. I assume Stenner intended that to be a reservoir to catch leakage but that is a fail during the rainy season when the reservoir remains filled with rain water. It's a nice little catch basin to provide a haven for mosquitos which is why I modified mine in this manner.
    Pool: 13k gal. in-ground; Stonescape Mini Pebble - Tropics Blue; Connected Spa - dual spill-over; Aqua Rite T-15 SWCG; AquaLogic PS-4 Automation; Sta-Rite DE Filter; Sta-Rite Max-e-Therm 400k BTU pool heater; Intellifo 2-VST Pump; Stenner 45mp2(25psi/10gpd) acid injection; Bulbwizard color LED pool lights; Poolvergnuegen 2 wheel side suction cleaner; FAFCO rooftop solar. TF-100 w/ speed stir.
    asquare's Avatar
    Sep 2016
    Lake Mary, FL
    17
    Thank you Jaimslaw! I was thinking of this option as well - good to know that it worked for you! Will do today.
    Dec 2014
    Riverside California
    474
    I also will do this mod. I usually just use an air hose to blow the water out after a rain, but your idea would work better.
    38000 Gal, IG, Plaster, 20' x 40' x 10', Attached Raised Spa, Intelliflo VS 3 HP (011018), Pentair Quad DE 60 Filter, Raypak (Rheem) 400,000 BTU (407a low Nox), Easy Touch 8 upgrade, Screenlogic 2 with wireless, IS-4 Spa Side Remote, Stenner 45MPHP10 w/15 gal tank, Intellibrite 5g (3), Dolphin Triton Plus robot with PRO remote, Water Tech Catfish handheld vacuum for spa, TF100 with SpeedStir.
    asquare's Avatar
    Sep 2016
    Lake Mary, FL
    17
    Attached the end result (and it rained heavily this afternoon!). I should have drilled slightly into the horizontal part so that all the water goes away but it took care of most of it.
    Jaimslaw's Avatar
    Jun 2015
    San Diego, CA
    299
    That looks good to me. I actually had some spare time on my hands so I made a little catch basin in/on the surface of the tank right up against the lip and then ran tubing as showing in your picks. (Wife as I was spending half a day having fun doing this mod: 'yeah, you have way too much time on your hands').
    asquare's Avatar
    Sep 2016
    Lake Mary, FL
    17
    LOL - wife is always right!
    Apr 2013
    Sacramento, CA
    2,769
    Just so we are all on the same page here the photo above shows a defeat of the chemical containment rim of the tank. The rim is required by OSHA and similar state rules to protect against release of the stored product in the event of an incident during the fill process.
    In a commercial installation or public pool it would be an OSHA violation and, depending on the state, possibly a crime.
    So generally this is something you should not do.
    Jaimslaw's Avatar
    Jun 2015
    San Diego, CA
    299
    if one's tank rim is filled with rainwater, how are containment objectives fulfilled during a refill incident?
    As you correctly pointed out, there really can't be an OSHA violation in the context of a residential, non work setting.
    For the record, I am no fan of OSHA - which started out as an agency with a reasonable set of safety objectives, but which of recent, has evolved into a typical overregulating organ of the state that has placed an unreasonable stranglehold on business. (reference: closing down construction site: reason, not enough drinking water dispensing containers on the job site).
    I'm sure OSHA has my best interest in mind when they compelled Stenner to design a reservoir in case I don't have the ability to properly pour liquid into a round hole.
