Thread: I need ideas on replacing pool pump on 5000G AGP
    20GT's Avatar
    May 2011
    Orlando, Florida
    50
    we have a sandPro 50 on our intex 5000 gallon above ground pool
    our pool motor gave out. we used to be able to spin the end <2> of it and it would start again but now it's completely given up the ghost.
    has anyone removed a SandPRO 50 or 75 pump from the motor<1>? is it just a shaft that the motor turns?
    can I attach a pulley and another motor?
    5,593 gallons of water at 80% capacity <Orlando, Florida>
    AG Intex Round Metal pole Swimming Pool - 16 Feet x 48 Inches (Intex A 16 X 48 F B02 11 01)
    Sand, SandPro 75 – 3/4 HP, 45GPM/2700GPH flow rate. GAM-4511 (Just days old 7/5/11)
    Crystal Clear Still
    Re: I need ideas on replacing pool pump on 5000G AGP
    Looks like you can buy replacement pumps for them. I was curious because I just purchased a Game 75D and installed it a week ago. How long did you have the pump before it went out? How much did you run it? Thanks for any info?
    Dennis in Central Indiana
    Pool owner for 4 seasons. 18 x 52 (7000 gallons) Intex Metal Frame pool. Hayward S210T93S Sand Filter and Pump (1 1/2 HP) w/ in wall skimmer. Taylor K2006 test kit w/speed stir.
    What is TFPC? Pool School Chlorine/CYA Chart Pool Math Recommended Test Kits
    20GT's Avatar
    May 2011
    Orlando, Florida
    50
    Yes I could buy a replacement pump but it's as expensive as buying a new unit when all is said and done.
    I've had it for over a year and a half. It's a good unit.
    I was hoping to find someone that's pump fanatic in do it yourself style.
    I'll break it down and see for myself. I think I can get a decent motor cheaper than what they want.
    Or hook up a sprocket, chain and attach my gokart engine
    I see. We have a local guy a friend told me about who rebuild electric motors. I guess he carries a lot of rebuilt ones in stock and you can just trade your bad one in for a rebuilt one. That's about the only suggestion I would have then is try to find a local guy like that in your area. Good Luck!
    Feb 2009
    Hampstead, NC, transitioning to Perfection, NC
    361
    There is a difference between repaired and rebuilt. That difference may not be valid for this situation. It is not cost effective to rebuild a motor smaller than 5hp. That being said, a lot of motors simply need a capacitor, start switch or a bearing to work quite well. Replacing a motor is a common situation, just make sure that you get the right replacement seal and bearing. If you do use the go-kart motor, pictures are requested. Have you ever tried out for the Darwin Awards? LOL!!!
    16X32 AB, Pentair SD filter, 3/4hp Pentair Optiflo, CircuPool RJ30+ swg, TF 100, 19 X 37 igv, Pentair filter, 1hp Pentair Superflo pump.
    Yes, I should have said repaired.
