Thread: Aqua Rite problem
    gregg4565's Avatar
    Jul 2013
    Tucson AZ
    12
    Aqua Rite problem
    I have a Hayward aqua rite system with a new T-3 cell that was replaced under warranty about 2 months ago . I've been noticing the lÁd display is acting weird lately ,if I touch any of the buttons on the display the lÁd starts to flicker and the numbers get distorted.
    Im also having an issue with the cell setting changing by itself, I set it to T-3 and a few days later I see the salt levels are all wrong and look and sure enough the setting is on a higher cell setting then I previously set.
    Could this be a bad mother board ?
    Any help would be appreciated.
    11,000 gallons
    in-ground
    Hayward sand filter
    1 hp hayward energy flo rs
    Built in 2000 (aprox)
    Swim pure plus SWG
    Jun 2011
    Long Beach, CA
    2,671
    Re: Aqua Rite problem
    Turn off the system and unplug the DSP board and plug it back in. Sometimes the connections go bad and this reseats the board. If that doesn't fix it make sure you have it checked out while it is under warranty.
    Apr 2016
    Lake Cormorant, MS
    4
    I just had the same issue a couple of weeks ago and it was the display panel. Amazon was the cheapest.
    12K gal, Vinyl AGP, 1.5 HP Waterway pump, 26" Ecokleer Sand filter, Hayward Aquatrol SWG, TF-100 test kit w/SpeedStir, Taylor K-1766 Salt Test Kit, Dirt Devil D2500 Pool Cleaner.
