Thread: Closing after a couple days of rain?
    Oct 2016
    PA
    1
    I'd like to close my pool this weekend, but it has been raining for a couple of days. Even though I've shocked it recently, should I wait and ensure all my chemicals are settled back down after the rain stops before I close it, or will it be ok? The water temp is below 60.
    Catanzaro's Avatar
    Jul 2014
    Monmouth County, New Jersey
    2,195
    Re: Closing after a couple days of rain?
    What exactly you mean by "ensure all my chemicals are settled back down after rain stops"? Your PH may be slightly affected. Once a pool is closed, depending on the cover, rain water enters the pool for quite a long time. If you have followed the closing procedures, described here on the forum, then go ahead and close your pool. Please add your signature and welcome to TFP!
    14,700 gallons IG Pool Vinyl Liner - Octal Circulation System
    Hayward Pro-Series 350 LB. Sand Filter Model # S270T - 2" Plumping
    Hayward CL2002 Chlorinator - Hayward Super Pump 2 HP Model # k48m2n111
    Hayward AQR9 SWG 25K Salt Cell & TF-100 Test Kit + Speed Stir
    Gulfstream HE125RA - 117K BTU Heat Pump - Date of Build is 11-2013
    30,107
    Rain doesn't have nearly the affect on pool chemistry that folks think. Run your pump for an hour to mix it all in and test your water......you should find little difference and then close it up.
