Thread: Need help with Pool return line eyeball
    Sep 2016
    Roseville CA
    1
    I had to remove two eyeballs from the return lines of my inground plastered pool. The parts got a bit "chewed up" in the process. And I am not sure if I got the whole thing or if there is still part of the assembly still inside the pipe. The pool plaster encases the end of the return pipe, so it looks like there are only these two parts. I have attached a photo of the two parts I removed: the eyeball itself and a small locking ring with two protrudung edges used to spin the ring onto the threads to hold the eyeball in place. The pool was built in 1996.
    Does anyone recognize the brand and type of eyeball?
    If so, where can I order new parts OR what brand/model would be a suitable replacement?
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    27,124
    Re: Need help with Pool return line eyeball
    That looks like a standard return eye........You can contact Swimming Pool Supplies, Pool Safety Cover, Swimming Pool Covers, Swimming Pool Pumps, Pool Pump Parts - INYOPools.com
    to make sure. I would take a pic or few with a tape measure to share with them. They have awesome cust. service. Make sure to tell them TFP sent you!
