Results 1 to 7 of 7
Thread: Help, please!? Drainbuster is stuck!!
    Jul 2007
    The Right Coast
    23
    Hi. I am sure there's a clog between my main drain & the skimmer basket. I tried to snake it & it got stuck. So I put the drainbuster in there, & I could see some stuff coming out of the drain, but not much. So I pushed the drainbuster down as far as I could. And now it's stuck. The water is off, it's been off for more than a few minutes, and it & the hose are stuck in there.
    What do I do?????!!! If I call my pool-guy-friend he'll kill me!!!!!
    Thank you for any help!!
    ~J
    13,000 IG Plaster, 2hp whisperflo pump, 48 sq in pentair DE Filter, 1 skimmer, 2 eyeball outlets, 200 sq ft solar panels on second story, Auto Pilot SWG-36, Polaris ATV Cleaner
    Jul 2007
    The Right Coast
    23
    Re: Help, please!? Drainbuster is stuck!!
    Clarification....the snake didn't get stuck in there, it just couldn't go any further so I pulled it out. It's the drainbuster & hose that are stuck.
    Thanks!
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    I'd try turning the water on and off several times while pulling on it when it's off.
    Jul 2007
    The Right Coast
    23
    You mean you think we should continue to turn it on. Then off again & try again?
    Jul 2007
    The Right Coast
    23
    Okay. We're doing that, and we're getting nowhere.
    Someone, please help!
    Jul 2007
    The Right Coast
    23
    I found the solution on a plumbers' forum. We had to disconnect the hose from the spigot, then, twist it in a clockwise direction while pulling it out of the drain. Worked like a charm!
    Thank you to all who tried to help.
    SW Indiana
    9,199
    Quote Originally Posted by judurant
    Glad you figured it out.
