Thread: G3 Barracuda Hose...
    Jul 2015
    Port Neches, TX
    56
    Hi All,
    I *thought* I'd finally had it with the crappy hose sections on my G3. I'm on my second cleaner in 15 years and prolly my third or fourth box of hose. For some reason, at least two or three hose sections a season will self-destruct on one end so I made adapter bushings to use a regular one-piece manual cleaner hose, but that was worse. Guess it's off to E-Bay for another box of hose...
    Russ
    15x30 18k gallon fiberglass "Lazy 8" inground pool, Aquarite 40k salt generator, 1 HP pump, Hayward DE filter, Barracuda G3 (side port) cleaner.
    Jun 2014
    15,895
    Re: G3 Barracuda Hose...
    I have the same cleaner but honestly .... I've never used it once. But, couldn't you opt to use a standard vacuum hose in its place? Once that's not in sections? Or did the makers of G3 design that thing so only their size will fit?
    Jul 2015
    Port Neches, TX
    56
    Quote Originally Posted by Texas Splash View Post
    Well, it didn't fit so I made some adapter bushings so it did. The result shows in the 2nd pic, the hose twists into multiple loops and the cleaner ends up "stuck" up in one place. I guess the one-piece hose body is much lighter in construction than the sectioned hose from the mfg...
    Russ
    Teald024's Avatar
    Aug 2016
    Columbus, Ohio
    1,301
    I have a similar setup using the 30' Hayward hoses, except mine never twists. I have a few of those 4' lengths, but never tried them. One end of the blue hose should say "toward vacuum," and the other end say "toward skimmer" or something to that affect, molded directly into the white & blue ends. I think my white end is skimmer & blue is toward vacuum.
    It reminds me of the old days of telephone cord where the handle got twisted so much that the cord just wrapped around itself. I'm guessing in that your attempt to fix or adapt the hose, the twisty end was cut off or jammed up near the Barracuda cleaner. without that twisty end, the hose will twist up just as you see. A new hose may be in order just to get the twisty end you need.
    - Dave -
    Dave - Aqua Leader Elegance AGP 15'x30'x 54", 12k gallons, vinyl liner ... Hayward/SwimPro Voyager pump SW159412STL, 2hp, 2spd, Hayward/Voyager 175sf element filter SW175MDDVPAKS, Installed August 2016 ... Liquid Chlorine, Stenner, Woods 50015 timer ... TF-100 .... CYA/Chlorine Chart ... Recommended Levels ... Basic Care Schedule ... Extended-Test-Kit-Directions ... ABCs of Pool Water Chemistry
    Jul 2015
    Port Neches, TX
    56
    If you're talking about a built-in swivel at one end, my manual hose never had one. This hose would only fit one way, as the ends are M-FM. I'll have to look at the new ones and see, my hose is prolly 20 years old and ready for a dirt nap.
    Russ
