Thread: Motor running, but no movement in pool.
    Jun 2016
    Somewhere in the 405, OK
    8
    I recently got my pool motor fixed, and got it up and running just this week. Over the last couple of days, there seemed to be no issues whatsoever. Everything seemed to be running just fine, and I started the SLAM process, with plans to close the pool in about a week or two.
    However, I noticed a slight difference today. While the motor was running, there was no movement in the pool whatsoever. I shut it off, cleaned out the leaf basket near the motor, and checked to see if there were any clogs near the impeller, but didn't find anything. I also cleaned out the skimmer basket as well. Another thing that I noticed was that once I cut the motor on, water wasn't flowing at all; what happens is that the water in the leaf basket drains out, and only fills back up when I turn the motor off.
    Any, and all assistance is greatly appreciated. Thanks.
    Apr 2013
    Sacramento, CA
    2,769
    Re: Motor running, but no movement in pool.
    Is this an above ground pool ? CAn we get a picture of the equipment and the pool.
    mas985's Avatar
    Pleasanton, CA
    11,726
    What was the filter pressure when clean and what is it now?
    Mark
    Nov 2014
    United Kingdom
    215
    What is the water level at the skimmer?
    Is the skimmer flap jammed up?
    10,000 gallons inground Leisure fibreglass pool, Hayward powerline pump, Quality120 glass media filter, 27kw output air source heat pump and thermal cover.
    Retractable cover with Polycarbonate roof and glass side for all year round use. K-2006C test kit and Speed stir
