Results 1 to 12 of 12
Thread: How long to run the pump each day?
    Aug 2016
    Lodi, CA
    10
    Any California peeps on here? As we transition into the fall months, I'm wondering how long to set the timers for my pump and vacuum to run each day? Temps have been in the 90s but will be dropping down to the 70/80 range. Nighttime temps get down to the 50s overnight. Pool specs are in my signature and my chlorine numbers are stable. Any input from the professionals on here would be greatly appreciated. Thanks!
    15K gal. w/attached spa IG gunite/pebble, 2 skimmers, 1 floor drain, Hayward Pro Series high rate sand filter, Hayward max-flo pump, Pentair Mastertemp 200 Heater, Polaris pool cleaner, Taylor K-1005 test kit, city water restrictions, pool age >15yrs
    Sep 2016
    Escondido/CA
    636
    Re: How long to run the pump each day?
    There is a great article in pool school that, in summary, says "it depends" but also gives you some rules of thumb and guidelines.
    Miley me see if I can find it...
    Pool School - Determine Pump Run Time
    Jon -- 28kgal, IG, AquaBright, Attached Spa, ~1990, Quad DE 80, Easytouch8, IntelliFloVS-3050, Intellichlor60, IntelliPh, Dolphin DX6, City Water, K-2006/TF-100, SpeedStir, SampleSizer, San Diego, CA
    Aug 2016
    Lodi, CA
    10
    Thanks for that! I've been running the pump about 4 hours a day so sounds like I should maintain that and could possibly drop to 2-3 hours in the cooler months when no one is swimming.
    mas985's Avatar
    Pleasanton, CA
    11,544
    I usually go down to 1 hour per day during the winter without any issues. When it is really cold, I will sometimes just shut off the pump for a couple of weeks.
    Mark
    Sep 2016
    Escondido/CA
    636
    I run it with my pump on its slowest setting (just enough to trip the flow meter on my SWG) for 2x4 hours.
    Mia's it cools off I will drop the 4, to 3, and 2. Probably overkill.
    Sep 2016
    Escondido/CA
    636
    The reason for this is that the power it takes to move water follows a 3rd power relationship.
    Double the flow and you need 2x2x2 or 8x the amount of power. This is an oversimplification, but it translates largely in real life.
    So, 80 GPM x 1 hour takes a lot more total power than 40 GPM for 2 hours.
    Another way way to look at this is that at 1200 RPM, my filter pressure won't lift the needle off the 0 PSI mark. At 3x this RPM, it is at 20 PSI. So more than 20x the force with only 3x the speed.
    So so why not run at the slowest speed? Well at some point the pump loses efficiency if you run it too slowly, and if you are trying to skim, you won't get enough flow to get the floating thinks off the surface.
    Aug 2016
    Lodi, CA
    10
    Thanks for the additional insight! My pump seems to be one speed. I will play with it and see how my water responds to the 1-2 hour limits as the temps dip.
    borjis's Avatar
    Aug 2014
    Pacific NW
    2,072
    I run 2 hours a day in season. (May-Sept) (longer on weekends / heater running days)
    2 hours per week off season. (Oct-Apr) (only for suction robot vac cleaning every saturday morning)
    Dolphin E10 Cleaning Robot.
    Surf_ox's Avatar
    Aug 2016
    Cypress, TX
    40
    Does running the pump longer cause the chlorine to "burn off" quicker.
    13K; IG Pebble sheen [4,5,4] with sun deck; 2hp pentair cleaning the water through a Clean and Clear Plus; 2hp pentair flowing the natural rock waterfall and 3/4 hp powering the 2011 Pentair legend (AKA "THE DUDE")
    Mod Squad pooldv's Avatar
    DFW, TX
    24,042
    No, chlorine is only burned off by oxidizing organic matter and to the sun.
    Surf_ox's Avatar
    Aug 2016
    Cypress, TX
    40
    Quote Originally Posted by pooldv View Post
    Burn off might be the wrong word.
    Does agitating the water by running pump cause any incremental chlorine loss vs chlorine loss with pump off?
    DFW, TX
    24,042
    Burned off is fine, or used up or oxidized. Same answer. Pump on doesn't change anything.
