Thread: Pool Closing
    May 2015
    Central PA
    38
    Pool Closing
    I have an above ground pool and was wondering if I need to drain the pool below the scimmer? I have a plastic (almost tupperware) type piece that goes onto the scimmer opening to the pool and a plug piece for the jet return. I live in PA so we do get freezing weather in the winter.
    ABG 24' Filter Cartridge 13,600 Gallons
    Re: Pool Closing
    You will probably find out that those covers have a slow leak. I still had to drain below the skimmer because of that cover leaking. I did not want a slow leak into my skimmer and ice building up over the winter and i figured with the pool being closed for about 7 monts that would add up to be alot of water leaking out of the skimmer if we didnt get a hard freeze this winter and a very wet area by the pool so i just drained to below the skimmer. I did leave that cover on just incase something would happen with the pool cover and my water level went up. I'm from w. Pa
    24' x 52" VINYL AG 15,200 GAL.
    HAYWARD POWER FLOW LX 1.5 HP
    HAYWARD SAND FILTER
    Taylor K-2006
