Results 1 to 8 of 8
Thread: Pros and cons?
    4ever3's Avatar
    Aug 2016
    Tulsa OK
    50
    Pros and cons?
    What are the pros and cons of hard plumbing skimmer and return in on an AP?
    I would like to do it so it is a cleaner looking installation than the flex hose and I can't really see any drawbacks to it but want to ask. I know there are things this first time pool owner is overlooking.
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Re: Pros and cons?
    The only cons are the cost.
    4ever3's Avatar
    Aug 2016
    Tulsa OK
    50
    Re: Pros and cons?
    Thanks Isaac!
    Anyone else?
    24' x 52" Embassy (13,500 gallons)
    Pentair Dynamo 1 1/2 hp
    Pentair Sand Dollar
    banditig's Avatar
    Sep 2015
    Ohio
    466
    Re: Pros and cons?
    No leaky hose clamps, longer lasting. If you use valves and unions, make winterizing much easier.
    15x54 swim & play vinyl metal wall AG
    Hayward S210T sand filter 1.5 HP Pentair Superflo vs
    Rheem raypak 130,000 BTU mv ng
    Jacuzzi 345 whirlpool bath
    TF-100 test kit, HM digital com100 Wanda the Whale
    Jul 2012
    Chicago, IL
    374
    Re: Pros and cons?
    I don't see any other cons than the cost as Isaac mentions. I have an AG and went with flex PVC pipe just to make things a bit easier. I used unions as mentioned so I just break the unions and bring the pipes in for the winter. Being flexible they are easier to store. You may not have those considerations in OK.
    Dedicated TFPer since 2012 with recommended test kit
    AGP, 30 foot, 21,000 gallons with these homemade islands
    Hayward 150 sq foot cartridge filter, 1HP Waterway pump
    Raypak 400K BTU NG Heater! (Model 406a - installed 2015)
    Pool installed in 2006? (just a guess, pool came with house I purchased in June 2012)
    4ever3's Avatar
    Aug 2016
    Tulsa OK
    50
    Re: Pros and cons?
    Thanks banditig and Pauls234!
    Im gonna switch once the kids are done swimming, the water is 72 and they're still swimming nearly every day
    Pentair Sand Dollar
    RyanMcC's Avatar
    Aug 2013
    NH
    214
    Re: Pros and cons?
    The cons are cost and doing the work. I PVC'd everything except skimmer to pump, maybe I'll do that next year...
    "...chemistry is not an exact science" -Mario Andrada, Rio 2016 Olympics spokesman
    21' x 52" Radiant Metric Round ~10K gal AGP with Hayward S180t pump/sand filter.
    Caldera (Watkins) Martinique 340 gallon installed in basement, Bromine and ozone.
    Taylor K-2006 test kit.
    4ever3's Avatar
    Aug 2016
    Tulsa OK
    50
    Re: Pros and cons?
    Thanks for the input Ryan!
    Pentair Sand Dollar
