Results 1 to 10 of 10
Thread: Do you have a security system or video camera on your pool area?
    Aug 2016
    Pittsburgh PA
    316
    Perhaps this is a bit off-topic for a pool forum?
    I'd like to get some kind of security system for my pool area. Maybe a video camera too. Best case would be to have one that I can access and view remotely.
    Does anyone use something similar?
    May 2016
    Troy IL
    467
    Re: Do you have a security system or video camera on your pool area?
    I don't have one monitoring my pool, but we used to have a system set up on our old house when we lived in the city. We had a Q See system that I got from Sam's club for cheap (maybe $250). The cameras were not high def, but good quality still. They are easy to set up and not hard to install. The hardest part is running the wires.
    17,500 gallon IG Vinyl
    Pentair Tagelus TA60D Sand filter
    Pentair Challenger 1.5HP pump CFII N1 1.5A
    Taylor K-2006-A, Stenner 45MPHP10 auto chlorine feed
    Major_in_MS's Avatar
    Jul 2016
    Florence, MS
    92
    I bought an Alibi 16 Channel 1080p HD DVR from SuperCircuits.com and some outdoor cameras and cabling. I have not installed it yet though. This DVR brand has both iOS and android apps for remote viewing. There are a lot of less expensive DVRs that the one I ordered also, look around the site and see if you see something you like.
    24,200 gal., IG vinyl, 18' x 36' rectangular, average depth 5'. K-2006C
    Jandy SFTM22 sand filter, 1 HP Hayward Super Pump, Doheny's Discovery Robot.
    One skimmer, one main drain, two eyeball jets, and one return from the booster pump.
    One wife of 26 years (schoolteacher, first grade), four kids (ages 14,16,17, and 19).
    I work night shift (Pediatric RN) so most of my posts will be during the night.
    Isaac-1's Avatar
    SW Louisiana
    6,711
    I have one of these Amazon.com : Amcrest ProHD Outdoor 1080P WiFi Wireless IP Security Bullet Camera - IP66 Weatherproof, 1080P (1920TVL), IP2M-842 (Black) : Camera Photo installed outdoors to monitor gate access it works fairly well and can be set up either wifi or wired internet. It has built in motion sensing and file upload capability, however I am not using it that way, I have it connected streaming to an old computer running zone-minder under linux which has much more advanced motion sensing. It works fairly well for my purpose of recording all traffic in and out of the gate, although does not capture license plate info well at night. That is unless a moth lands in front of the lens like last night, then you get 220 motion events over 2 hours of moth legs and wings wiggling.
    Ike
    p.s. mine is set up about 1,250 feet from the house powered by a solar panel, and connected to a directional antenna
    txnole's Avatar
    Aug 2014
    Amelia Island, FL
    544
    I think you need to asess your security goals. You mentioned a security system and a camera, so something like an alarm/alert when someone enters the pool area? Can you give us an idea of what the area looks like? For example, is it an enclosed area that needs an alarm when the fence is breached or an open area with a water alert? Are you just wanting to chase off kids? Sometimes the fake camera with the red blinking light and a sign is all it takes. Are you wanting to archive use to track if someone was in the pool? Mobile alerts or mobile access?
    Sorry for so many questions, but this project could range from $9.99 to $999 and I'd rather you hit the right target for what you want.
    COMPLETED BUILD THREAD - 15'x29' rectangular offset shotcrete pool; 14,100 gal; 5'x7' raised spa with 400k btu fire feature; 7' spillover; 25' leuder stone raised bond wall w/waterfall; Pentair SWG; Pentair VS (pool); Pentair 3/4hp feature pump; 1hp spa blower; Pentair Cartridge filter; Pentair “Easy Touch 8” wireless; Dolphin Oasis Z5 robot; Solar Hydronics iSwim solar panels; Mansard Screen Enclosure; walnut travertine deck; 1 very happy kiddo.
    Killer95Stang's Avatar
    Sunny SoCal
    573
    I have a Q-see 8 channel NVR (Dahua) that handles 6 1080p bullet cameras around the house. Four of the cameras are PoE that came with my system. Two of them are Foscam FI9900p wireless cameras that I ended up using hardwired with cat5 cabling. The Foscam out by the pool is actually sending its signal through a Powerline adapter, since the wifi signal was out of range and it was too much of a hassle to run cat5 out to the pump pad. So far so good. I can view all my cameras on my phone and all of them record to my NVR. Only issue is the two Foscams can't be recorded using motion events with my NVR. That is compatability issue with Foscam and my Dahua based NVR. I solve that by recording 24/7 on the pool cam.
    Pool done!! (backyard = work in progress) 32' x 19' inground freeform with 7' spa, baja step w/ (2) bubblers, stonescapes mini pebble finish, rock waterfall feature, 12" raised bond beam, Intelliflo VS, Whisperflo feature pump, (3) 5G Color LED's, FNS + DE 60, 400K Master Temp, Easytouch 8 w/ remote, Intellichlor IC40, Vision Classic Ceramic Kamado smoker, Margaritaville DM1000!!! Party Coming Soon!!
    TF-100 Test Kit w/ Speedstir
    sheree202's Avatar
    Jan 2016
    Lawrenceville, GA
    245
    18 x 38’ gunite, 3’9”-7’ deep, 8 x 12’ tanning ledge with 8” deep water, umbrella sleeve, 2 LED bubblers.
    2 Pentair LED lights, 16’ long fiberglass hill slide and jump rock. Sand dune pavers/coping. TF-100. My build: Georgia Pool Build.... No Longer O/B :))
    Oct 2015
    Brookside Village/Texas
    3
    Check out the Arlo camera from Netgear. They are wireless, battery operated and rainproof. I have one mounted by my pool about 400' away from the base station.
    Aug 2016
    Pittsburgh PA
    316
    Thank you for these suggestions. I reviewed and reviewed - and ended up spending about 4 solid hours reading and rereading. In the end, I chose a Reolink system - https://smile.amazon.com/gp/product/...?ie=UTF8&psc=1
    Home Business Video Security Camera System Wired, w/2 Bullet and 2 Dome HD 1440P Waterproof Outdoor Indoor PoE IP Cameras and 1 PC of 8-Channel 4MP NVR Kit with Built-in 2 TB HDD, Reolink RLK8-410B2D2
    It has 4 cameras that are POE and a 2TB NVR for recording. I can access remotely. I can also plug a TV into the NVR (VGA or HDMI) and always be able to see whats going on. I am going to put 2 bullet cams in the pool area, 1 dome in the garage door area and 1 dome on our front porch. Reviews are decent and say that the support is very good. We'll see!
    As for pictures of my pool area.....well, I don't have a pool yet. I want to install this before the build because I want the build on video - to document the builder and for my own interest.
    @Isac, I was very close to buying that ProHD camera. I just don't know how I'd set up recording and ultimately decided I wanted multiple cameras.
    Dec 2015
    Chino/CA
    202
    Yes!
    I have "pieced" together a system with 6 cameras right now and and about to add 2 more!!! My main system (DVR, 4 cameras) I purchased directly from Swann.
    Chris B.
    New house w/ 28 y/o I.G. 15k gal. pool/spa, Plaster, Hayward DE-480S Micro Clear Filter, Pentair Whisperflo wfe-4, 1HP (Main Pump), Hayward SP2815x20 (Pump for spa jets), Versa Pool Heater, Hayward Pool Vac Ultra, TF-100 Kit
