Results 1 to 8 of 8
Thread: Any suggestions on how to secure winter cover to this pool?
    Jun 2016
    Baden, PA
    2
    Hello, I'm a first-year pool owner. When we were building the deck around this pool, I hadn't put sufficient thought into how I was going to secure the winter cover. I have a few ideas but I'd like some suggestions as well. I considered weaving the cable over and under the deck boards but was afraid I then couldn't draw it tight enough. Or possibly use water bags around the upper edge...
    Sentinelle Quantum Deluxe 15x30x54" above ground w/ Swimline unibead vinyl liner, wide mouth skimmer, Hayward Powerflow 2hp pump, Hayward SwimPro Voyager 110 ft2 cartridge filter, Nature2 A30 mineral sanitizer. Wrap-around Azek deck surface, half at pool height, half 2-ft below pool height.
    JoeSelf's Avatar
    Jun 2014
    Glassboro NJ
    321
    Re: Any suggestions on how to secure winter cover to this pool?
    Clips and wire for where you can still get them on. Maybe running the wire under the deck, but your gonna have to figure out how to secure to posts and joists to maintain the oval shape below deck. You could tie down to the wire below with rope thru the grommets along with a second loop running thru the grommets weaving under joists. (I"m not sure if a good wind wouldn't pull up the deck boards.) Water pillows to lay on the deck.
    13700 gal, 32'x16'x54" AG oval, vinyl, Echo Canyon II, 8500 series, Narrow Yard, Safety Fence & Stair, Sta-Rite Crystal Flow T-210WF, 44 GPM, Hayward SP1580TL 1HP Pump, Aqua Luminator, Festiva wedding cake steps, March 2006, TFT-100, Speed-Stir, Sample Sizer. Avatar Credit: TJ Townsend
    Jun 2016
    Baden, PA
    2
    That's a great idea, thanks! I can drop down through the deck at places where the tie-down to the cable can catch a joist as well.
    May 2015
    Walden, NY
    10
    I'm curious to know how did you end up securing the winter cover. I'm in process of building a parcial deck at the end of my 18'X33' AG and I'm not sure how to go about securing the winter cover. I wonder if I could install the brass anchors that they use on IG pools on the decking boards.
    Thanks!
    18'X33'X52" Aqua Leader. Hayward Perflex EC50 Filter System With 1.5 HP Pump.
    Jan 2013
    Long Island, NY
    176
    Quote Originally Posted by aprendiz View Post
    Thanks!
    My neighbor has a semi inground with a deck half way around. He drilled through the deck and inserted female threaded anchors, and tightened eyebolts through through the grommets of the cover. On the side with no deck, he tied rope through the grommets and anchored the rope to concrete block. He's been doing this for the last 17 years and the cover has never blown off or collapsed under a wind, snow load or water load. However, he does pump the cover off when it accumulates water.
    Doughboy 12' x 20' Saphire semi-AG, Installed 2012
    Waterway 1.5 HP 2 speed, 100 sqft cartridge filter
    Aprox 7000 Gal, Full sun, 85K heat pump,
    TF-100 test kit
    May 2016
    Belleville, Ontario
    17
    I'm curious to know how you made out as well. My deck is similar except it's enclosed around the whole pool.. this is what we dealt with all fall and spring.. 😔 thankfully the winter ice helped with this problem... I would love to find a solution so that the cover isn't being blown up and pulled off all the time...
    noobie :-)
    16x32 oval 'on ground' vinyl, 13700 Gallon, 48" depth, rocky roller, Hayward Ultra Pro LX pump, Carefree 150lbs sand filter, TF-100 test kit
    mariane's Avatar
    May 2012
    Southeast Michigan
    289
    Don't have a pic, but we secure the cover on the deck portion with the heavy sand weights we use to hold down the ladder during swim season. The sides that have no deck-the cover is held down by hanging jugs of water from the grommet holes on the cover. Never blows off but does fill up with some water. So now we clean off the cover, the weights and dump out the jugs and start the opening process.
    16 x 28 Doughboy Mystic Garden AGP with 7' deep end (used expandable vinyl liner) ~11,800 gals. Deep end main drain. Thru-the-wall skimmer, one return at deep end. Media Master 150# sand filter. Doughboy PowerPak II pump, 1 hp. Pentair MinimaxCH 150m natural gas heater. Polaris 65 when it feels like working . TF-100 test kit. No longer 'pool stored' 5 years and counting. In sunny but fickle metro-Detroit.
    Jun 2015
    Ottawa/Ontario
    335
    Water bags
    18000 IG, SWG, 1/2 HP Tri Star + Solar PV direct DC Lorentz pump, Sand filtrt
    20000 gallon, IG, SWG, Sand Filter, Hayward 1/2HP + Lorentz direct solsr PV pump
