Thread: Ladder post hole
    Jun 2016
    New England
    98
    Ladder post hole
    I pulled my ladder out and the two holes filled up with water. Is there anything I need to do to prevent them from freezing and cracking the cement?
    Christopher
    21' x 43' IG 40K Gallon vinyl and concrete pool; liner: 2016; Hayward DE7220 filter; Maytronics M400; TFT-100; Speed-Stir
    Major_in_MS's Avatar
    Jul 2016
    Florence, MS
    94
    Re: Ladder post hole
    Wash them out with a nozzle on the end of a garden hose. There should be a drain/weep hole in the bottom of them but it may be clogged up. If that does not work then you can probably stuff a piece of a pool noodle in there to dislodge some water and just leave it in there over the winter to absorb any freezing pressure from water remaining.
    24,200 gal., IG vinyl, 18' x 36' rectangular, average depth 5'. K-2006C
    Jandy SFTM22 sand filter, 1.65 HP PureLine VS Pump, Doheny's Discovery Robot.
    One skimmer, one main drain, two eyeball jets, and one return from the booster pump.
    One wife of 28 years (schoolteacher, first grade), four kids (ages 16,18,19, and 21).
    I work night shift (Pediatric RN) so most of my posts will be during the night.
