Results 1 to 7 of 7
Thread: Got a pipe installed, should I add a return?
    Jun 2016
    New England
    98
    I have a 20.6" x 42.6" pool that has one skimmer, one main drain and two returns. There is a third pipe run that used to be for some cleaner or something but it is currently closed off. I was thinking about making this another return and piping it into the existing returns. This will be really easy as it is right next to it.
    I have no use for it otherwise, is there any benefit to this?
    Otherwise, I was just going to cut the pipe by the filter side and cap it below ground.
    Christopher
    21' x 43' IG 40K Gallon vinyl and concrete pool; liner: 2016; Hayward DE7220 filter; Maytronics M400; TFT-100; Speed-Stir
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Re: Got a pipe installed, should I add a return?
    It might help, depends on location, etc. I doubt if it would hurt, and may lower back pressure on plumbing and increase your flow
    30,104
    Another skimmer would be my first choice but another return can be beneficial as well. I would use it for one or the other.
    Jun 2016
    New England
    98
    The hole is already in place in the wall for a return, it's just got the border plate but no cut in the liner. Making it a return would be super simple. I'm sure it can be a skimmer too, but it is extremely close to the existing skimmer (within a foot or so).
    Christopher
    mas985's Avatar
    Pleasanton, CA
    11,543
    Is the MD plumbed through the skimmer or are there two separate lines going to the pump from each.
    If there is fairly high head loss on the suction side (single run) and you reduce the head loss on the return side with another separate return, it is possible that the pump could start to cavitate.
    Mark
    Jun 2016
    New England
    98
    Quote Originally Posted by mas985 View Post
    There are two pipes going up to a cut off valve that allows me to do 100% drain, 100% skimmer, or 50/50. Then there are two returns that go in via another pipe.
    Christopher
    mas985's Avatar
    Pleasanton, CA
    11,543
    That should be ok then.
    Mark
