Results 1 to 13 of 13
Thread: skimmer not skimming leaves after installing polaris 360
    Jul 2016
    Gainesville, FL
    118
    previously I had 2 returns, 1 skimmer. The skimmer used to fill up every day with leaves. Now I installed a polaris 360 at the vacuum port (which was previously closed). Problem is, leaves tend to move towards the skimmer but turn away before they get in. Any idea what's causing this strange water flow in the surface?
    pool layout:
    http://imgur.com/a/bYKI6
    Inground 28000 gal Concrete, Hayward Progrid DE filter 6020, US motors 1.5hp pump (3450rpm) , Polaris 360
    600 gal hot tub, Spa Vita, Nature2+MPS
    Mod Squad Jimrahbe's Avatar
    Jul 2014
    Bedford, TX
    6,058
    Re: skimmer not skimming leaves after installing polaris 360
    I can only assume that without the Polaris your skimmer was getting 100% of the pumps suction. Now, with the Polaris your skimmer is only getting 50% or less of your pumps suction. Is your Polaris running all the time the pump is running?
    Easy to test. Feel how much water is flowing into you skimmer with and without the Polaris connected.
    Curious, why is one return "restricted" ?
    foobert's Avatar
    Jul 2013
    Bay Area, CA
    143
    I thought the 360 was a pressure side cleaner? Is the there a suction-side version as well?
    ~john
    24.5K G, pebble, SuperFlo VS 1.5, 48sq DE filter, Hayward H250FDN, Autopilot RC-52, Poolvergnuegen & 3 daily swimmers in season.
    Jul 2016
    Gainesville, FL
    118
    Quote Originally Posted by Jimrahbe View Post
    360 is pressure-side vacuum. The other jet is restricted to direct more flow to the 360
    triptyx's Avatar
    Apr 2016
    1,209
    So it sounds like the pool isn't circulating the same way because the returns are no longer being utilized at their full level?
    8,500gal plaster in-ground with attached spa, two floor drains, one skimmer. Chlorine, City Water.
    Pentair WhisperFlo 1hp Pump, MagnaTek Midcentury EPlus motor, Pentair CleanNClear 200SF Cartridge filter, Purex Triton MiniMax 250 Gas Heater, Pentair SunLite, AutoFill.
    Kreepy Krauly Cruiser, TF-100 with SpeedStir. :D
    Major_in_MS's Avatar
    Jul 2016
    Florence, MS
    92
    So, if you connected the Polaris 360, which is a pressure side cleaner, to a vacuum port, then first of all the Polaris 360 would not be working correctly and second of all the vacuum port, which is now open, is robbing suction power from the skimmer. (Are there too many commas in that sentence?)
    Are you sure you connected it to a vacuum port? Do you have a valve to switch the vacuum port to a pressure port?
    24,200 gal., IG vinyl, 18' x 36' rectangular, average depth 5'. K-2006C
    Jandy SFTM22 sand filter, 1 HP Hayward Super Pump, Doheny's Discovery Robot.
    One skimmer, one main drain, two eyeball jets, and one return from the booster pump.
    One wife of 26 years (schoolteacher, first grade), four kids (ages 14,16,17, and 19).
    I work night shift (Pediatric RN) so most of my posts will be during the night.
    harleysilo's Avatar
    Mar 2012
    North Georgia
    1,924
    My Polaris has a valve on the hose near where you plug it in to the return. It allows excess water pressure to exit, with some force. Depending on which way the relief valve is pointed it could be causing the leaves to not go in the skimmer, assuming it's plugged in near the skimmer.
    18'x43' Sport Pool
    19,000 Gallons Vinyl Liner 3'-3.5'-4'
    SWCG and D.E. Filter
    Test Kits - Pool Calculator - Chlorine/CYA Chart - Pool School
    Secret Weapon for Pool Chemistry Testing
    Jul 2016
    Gainesville, FL
    118
    Quote Originally Posted by Major_in_MS View Post
    what I mean by "vacuum port" is the return line intended for vacuuming/cleaning
    Jul 2016
    Florence, MS
    92
    Quote Originally Posted by archer636 View Post
    Does this port have suction, as in it pulls water out of the pool to the pump, or is it a return, meaning that pressurized water comes back into the pool?
    Jul 2015
    Central Valley CA
    1,077
    I would focus on the skimmer check that the weir door is not stuck down it should move easy. Also check that it is floating well depending on how it is made if it gets cracked it can get waterlogged and ride a bit low in the water. It should allow a thin layer of water to pass over the top, the thinner the layer the more velocity to pull the leaves in.
    12,300 Gallon, IG PebbleFina, 3 ft sheer, 2 Jandy nicheless LED lights, Jandy Pro 1.5HP VS pump (A.O. Smith Motor), PB4-60 Booster pump, Polaris 280, Jandy cv340 cartridge filter, Zodiac Z4 control panel W/iAquaLink, Stenner pumps for chlorine & MA connected to WiOn WiFi switches, TF-100. You can support TFP with AmazonSmile just click the link!
    Jul 2016
    Gainesville, FL
    118
    Jul 2016
    Gainesville, FL
    118
    FYI- all I had to do was to tilt the eyeballs up slightly to create waves.
    triptyx's Avatar
    Apr 2016
    1,209
    Thanks for the update! Be aware that making waves like that will likely cause your pH to rise a little faster than it would otherwise. This isn't a problem as long as you keep an eye on that and your TA.
    Cheers.
